line lock kits for fbs?
Old Nov 12, 2003 | 11:30 PM
Gregs's Avatar
http://store.summitracing.com/produc...earchtype=ecat
that is the only thing i could find
and it says they are sold in kits
does anyone have line lock on there fb and if so could you lemme know where u got the kit?
thanks
-greg
Old Nov 13, 2003 | 09:01 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
you will need two kits I believe.
because of the brake setup on the FB. One for each front wheel.
Old Nov 13, 2003 | 09:05 AM
joebeer's Avatar
you dont need two kits. but the hardest part is to find the right fitting to mate the brake line to the line lock cylinder. it would be easier to just grab a set from a junk car, cut the end (master cylinder side) and use fitting from the line lock kit (this is separate).
Th0m4s
Feb 26, 2019 02:04 AM
astrum
24
Nov 15, 2017 08:44 AM
diabolical1
30
Jan 30, 2016 05:50 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
