Sponsored by: CARiD
Can someon help me out??
Old Nov 12, 2003 | 01:26 AM
SkrillaRx7's Avatar
Newbie
Unhappy Can someon help me out??
My mtor leaked water really bad and overheated, so i replaced the water pump, it leaks water out the exgaust and my spark plugs are wet and water leaks into my oil??? is it blown?
Old Nov 12, 2003 | 02:09 PM
Project84's Avatar
Open up! Search Warrant!
sounds like a blown coolant seal. have to rebuild the engine to fix it, coolant seals cannot be accessed from out side of the engine. It must be removed from the car and rebuilt.
Old Nov 12, 2003 | 04:08 PM
wwilliam54's Avatar
it WILL run
luckily its not expensive for the parts if the housings are fine
~100$ gasket kit should get it running
Old Nov 13, 2003 | 12:38 AM
SkrillaRx7's Avatar
Newbie
would it work if i just put another block in and put all the parts from old one on it??
Old Nov 13, 2003 | 03:22 PM
wwilliam54's Avatar
it WILL run
dp
wwilliam54's Avatar
it WILL run
you have another engine?
then yuh
Joe428
Sep 29, 2015 06:58 PM
Frox
Comments and Suggestions Archive
Sep 18, 2015 06:32 AM
