Max boost with the stock air box?
Old Nov 11, 2003 | 08:56 PM
MtnRacer's Avatar
infini guru
Nevermind the why, let's just focus on the how. After some discussion, I gather that the airbox isn't so much restriction until the higher rpms(i.e. I might see 11psi at 4k, but not at 6k). So how much boost would I see at high rpms, and at what rpms specifically?
Steve
P.S. Assume we are not using the stock filter(maybe a K&N or something?), but ARE using a straight through exhaust(3").
Old Nov 11, 2003 | 10:25 PM
Ryde _Or_Die's Avatar
Every car is going to be different more than likely. I would say with stock i/c and just 3" straight exhaust without cats and only a K&N drop-in...maybe 9psi. Assuming a stock wastegate/turbo as well.
Old Nov 11, 2003 | 11:20 PM
mrb63083's Avatar
i remember with my stock intake, i couldn't get boost over 5k rpm, So i cut the top out where it says 'mazda' and it worked. and i have stock turbo and intercooler with full exhaust. oh and at 10psi
Old Nov 11, 2003 | 11:24 PM
MtnRacer's Avatar
infini guru
err, could you clarify that post a bit please? You got 10 psi after you cut the top out of the box I'm assuming, what did you get before? It's the before I'm interested in. Thanks!
Steve
Old Nov 11, 2003 | 11:39 PM
Wankel7's Avatar
Haven't we ALL heard this
http://www.autospeed.com/cms/article.html?&A=0629
Read that if you really want to learn about intakes.
James
immanuel__7
89
Sep 5, 2015 10:23 AM
Snook
Aug 15, 2015 08:18 AM
Wolf_
Aug 11, 2015 04:23 PM
