Lots of wheelspin with 285's out back and about 400 horses?
Old Nov 10, 2003 | 09:34 AM
mrgracer's Avatar
Question Lots of wheelspin with 285's out back and about 400 horses?
If I had the apexi rx6 turbo kit, producing a little less than 400 horses at the wheels, would 285 hoosiers in the back stick well? Is anyone running anything like this? How much wheelspin do you get? I don't want to be spinning through 4th gear or anything. Thanks.
Old Nov 10, 2003 | 10:17 AM
stangkilr's Avatar
It's only got one turbo
even if u were running 225s, u're gonna need a lot more than 400hp to spin through 4th gear, lol...
Old Nov 10, 2003 | 12:23 PM
ptrhahn's Avatar
You're likely talking about 285/30/18, right? For straight-line traction, you'd be better off with something with a little more sidewall... like maybe a 275/35/18
This was illustrated to me by my friends old 700-hp Supra, that would virtually liquify his 285/30 S03s in any gear. 275/35 S03s helped considerably.... 275/40/17 might be even better...
Old Nov 10, 2003 | 04:20 PM
vosko's Avatar
Just Call Me Terminator!
my FD would spin 1-4 gears with 255/40 kumho on a 17x9 rim.....that was fun
Old Nov 10, 2003 | 04:57 PM
DamonB's Avatar
Originally posted by vosko
my FD would...
It's funny how whenever you speak of one of your cars it's always in the past tense
Old Nov 10, 2003 | 06:58 PM
vosko's Avatar
for some odd reason. i don't think my FD can do that anymore ?? hmmm
Old Nov 10, 2003 | 07:15 PM
maxcooper's Avatar
WWFSMD
While the 285/30-18 setup offers nice grip in the corners, I commonly slip the tires when starting from a stop in first gear completely by accident. I am running BFG g-Force R1A tires in that size for track stuff. I have done this a number of times just trying to get a brisk but not overly aggressive start -- just coming out of the pit onto the track. Come to think of it, second gear goes up pretty quick, too, but it might just be the marbles.
Or at least I was two years ago, but I haven't been to the track since then. I am sure my R1A will be even easier to light up when I run them next time.
-Max
Old Nov 10, 2003 | 09:46 PM
80-CU.IN.T's Avatar
First and second gear is very touchy with anything around 400 RWHP unless you have slicks. Even then if they are not up to temperature, you will get wheel spin. I made a manual boost control just for this reason. 1st & 2nd low boost, push a button and now higher boost.
Old Nov 10, 2003 | 10:23 PM
ZoomZoom's Avatar
SEMI-PRO
I smoke the tires all the way though first and second with my 285/30/18 Bridgestone S-03's Even from a roll they spin in 1 and 2. 3rd gets some slipping but more moving and slipping. Get R compound drag radials for the back just watch out during thr rain.
Old Nov 11, 2003 | 09:15 AM
CCarlisi's Avatar
Rebreaking things
Great solution if you only want to go in a straight line
Old Nov 11, 2003 | 09:19 AM
vosko's Avatar
i love my 275/40/17 nitto 555R2 good traction and good for handling
A$$
i love the 100 treadwear rating too
Old Nov 11, 2003 | 09:44 AM
redrotorR1's Avatar
LS6 Convert
Re: Lots of wheelspin with 285's out back and about 400 horses?
With a Hoosier, you're going to get wheelspin due to the stiff sidewalls. And with a low profile tire, it will additionally make it easier to spin the tires. The 275/40 17 suggestion is not a bad idea in terms of reducing wheelspin. enuttage's FD makes ~380RWHP and is running on 275/40's in the rear ... he doesn't seem to have any wheelspin problems.
I don't think you'd have a problem spinning the tires with 285/30's with a soft enough street tire. I'd think you need to making a lot more HP than 400RWHP to spin 285's in 4th gear.
Old Nov 11, 2003 | 11:40 AM
mrgracer's Avatar
Well, 4th gear was an exageration(however you spell that fkin word), but I do want excelent traction along with about 400 whp. Maybe I should have changed the thread to: What kind of tires( size and brand) do I need to have great road racing traction with 400 whp? I don't wanna go with 18's, and I really don't weanna have to put a widebody on it, so any suggestions would be appreciated. I think that was the thread I was meaning to start.
Old Nov 11, 2003 | 11:47 AM
mrgracer's Avatar
Oh yeah, price doesn't matter.
Old Nov 11, 2003 | 11:49 AM
ptrhahn's Avatar
Without 18s, you're talking 17's. Get a 17x10" wheel in the rear, and mount a 275/40/17. Its a very common size w/ lots of choices.
If you go with an R compound, you can try drag radials for straight-line performance, or even a track tire like a Toyo RA1 or Yoko A032, both available in that size.
For street tires, try a BFG KD or Toyo T1S, Yoko AVS Sport or perhaps the Nitto that Vosko was talking about. S03s are a good tire, but only available in 265/40/17.
Old Nov 11, 2003 | 11:51 AM
vosko's Avatar
the nitto's were cheap too! $180 each shipped!!! not bad at all
Old Nov 11, 2003 | 12:52 PM
BFG TA KDs will be your best bet, if money is not an issue, you could also run Toyo RA1s, they will stick better, and last almost as long. I would not run any other R compound, they will get very hard, very fast. Neither of these tires is safe in heavy rain above ~55-60 mph, unless brand new. These are not guesses, I have run all the tires mentioned above(except the nitto, which was only available in a 275-40-17) on cars with silmilar, or greater HP, both road racing, and street. Hope this helps, Carl. BTW, on any of the others, I can let you know why not if you like.
Old Nov 11, 2003 | 01:58 PM
SleepR1's Avatar
Yeah with 17s you're limited to 275/40-17 on 10 x 17 wheels. You could run this all the way around with 2.5-inch coil springs. 275/40-17 is 0.7 inches taller than stock in overall tire diameter, so your car might look a little raised. If you have ride-height adjustable shocks you can lower the ride height, but then you'll get tire rubbing fender lips. 265/40-17 on 9.5 x 17s might work out better.
Personally with cold tires, you can light any tire up with LESS than 400 rwhp. My advice would be to warm the tires up before really opening up the throttle.
Old Nov 11, 2003 | 02:36 PM
ptrhahn's Avatar
I've got that combo on right now... 17x10" +44 Fikses w/ 275/40/17 S02s. No rubbing, and no coilovers needed (even though i happen to have them)
See the thread below for pics of my car w/ 17x9" SSRs w/ 275/40/17 rear bridgestone RE71s (the largest 275-section tire i've ever seen, about 1" wider on a 9" wheel than the S02 on a 10"). I don't see why you'd want to run a 275 up front on the street, but you would need coilovers for that. I run a 235/45/17.
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/pics-7-a-206648/
Old Nov 11, 2003 | 02:57 PM
SleepR1's Avatar
Yeah, Pete, I was suggesting 2.5-inch coil springs for running 275/40-17s all the way around to preserve the neutral handling and turn-in response
Old Nov 11, 2003 | 03:17 PM
ptrhahn's Avatar
Manny, are you trying to say that my car doesn't handle neutrally or turn in crisply?! :-)
Old Nov 11, 2003 | 05:56 PM
ouch vosko that sucks man. gonna get a new one?
Old Nov 11, 2003 | 07:45 PM
vosko's Avatar
getting out of debt. i have a 90 T2 that is being built up
Old Nov 13, 2003 | 06:29 AM
SleepR1's Avatar
Nah, I'm just saying why I'd go 10 x 17 all the way around Glad you like your new setup
Old Nov 14, 2003 | 08:21 AM
enuttage's Avatar
Chicharrones Rule!!
Beating a dead horse....
Yeah, 275/40/17s are gonna help, a lot.
As RRR1 mentioned, I'm running these in the back with 378rwhp (with the RX6) and having few issues with wheelspin.
Obviously when they're cold it happens, and every once in awhile, if I really nail it, or if the surface isn't perfect it'll slip good, but nothing compared to the 245s on the car previously.
Good tires too. Kumho MXs. They seem to be gripping nicely and wearing respectably.
G'luck with the setup.
paz,
-E
immanuel__7
89
Sep 5, 2015 10:23 AM
OrangeMax
Aug 22, 2015 12:05 PM
