Hard turnover when cold
Old Nov 5, 2003 | 01:16 PM
natew's Avatar
Whenever the car is butt *** cold.. It doesn't want to start you can hear it turning over but it is sooo slow at first and all the lights on the dash almost go completly out but eventually you can hear it pick up a little speed and it starts up.. so whats the deal? Do I need a new battery or somethign else?
Old Nov 5, 2003 | 06:05 PM
O 16581 72452 5's Avatar
The infamous number guy!
You need a battery with more cold cranking amps.
Old Nov 6, 2003 | 01:10 AM
exodus82's Avatar
Pump the pedal 3 times quickly with the choke all the way out, and turn the key. Dont touch the gas until you hear it just about start or youll flood it.
Old Nov 6, 2003 | 01:14 AM
This has nothing to do with that.
His problem is an electical drain because the battery cannot supply enough amps.
Good tip, but not his problem.
Old Nov 6, 2003 | 02:25 AM
personally, i don't find flooding a rotary engine easily, but exodus is on the right track.
and just to second it, yes, sounds like yer battery is drained, and go buy a brand new one.
Old Nov 6, 2003 | 03:27 AM
FB II's Avatar
get an optima red top!
Old Nov 6, 2003 | 10:46 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
What weight oil are you using?
Old Nov 6, 2003 | 10:59 AM
natew's Avatar
20w50 oil.. im here in CA so its only getting down to like 40 right now at the lowest.....
Old Nov 6, 2003 | 02:13 PM
Jeff20B's Avatar
Lapping = Fapping
Your battery may be getting tired, but check you starter too.
Donald Hampton
16
Nov 23, 2022 06:38 PM
sinistersam
Sep 13, 2015 07:17 PM
Nosferatu
Sep 5, 2015 02:13 PM
