Microtech engine boging with new street port
Old Nov 3, 2003 | 06:17 PM
Mark'sMazda's Avatar
stop stealing my avatar
My car (s4t) used to run, and drive great with the old motor and ignition map. When the motor bit the dust, I had an S5 rebuilt/street ported and put that in. With the new ported motor, I had to change the old map quite a bit to get it to idle steady, and have a smooth idle/light load transition.
There is one bug I can't work out, the car badly bogs on up shifts. If the car is idling and I rev it, it will rev cleanly. If I am holding it at a steady RPM, and rev it, it revs fine. The problem is if the rpm's are falling, and I blip the throttle, the car will bog badly, and will almost die. The bog is usually met with a small back fire when the motor "catches". This makes up shifting smoothly quite difficult, and matching revs on downshifts almost impossible.
The motor has about 100miles on it, so I am keeping it under 4k, out of boost. Any help/tips would be greatly appreciated. I don’t have a laptop, or wideband, only the dash unit.
Old Nov 3, 2003 | 06:22 PM
10sec rx7's Avatar
it just sounds too lean in the 10,5 and 0 maps, add some more fuel to them and see how that goes, you may also have to add some fuel to pump1 and 2
dale
Old Nov 3, 2003 | 06:55 PM
HIMNI Racing's Avatar
Rick James
Doesn't back fire normaly = rich?
Old Nov 3, 2003 | 09:09 PM
10sec rx7's Avatar
depending on the back fire,
if it is coming out of the exhaust it generally means it is rich but a bad flat spot and pop from the intake means it is lean,
dale
Old Nov 4, 2003 | 01:09 AM
thanks for the replys.
The back fire is comming from the exhust.
adding fuel to the 10, 5, 0 maps didn't really help. I was adjusting them in the idle map. should I be using the load map? please bear with me as I am a bit timid with this tuning thing, especially after forking out the cash for one rebuild.
It seemed to get a little better when I added some fuel to pump2, but the problem is still there. I went up 6%, on pump1, and pump2. how much is too much?
After changing spark plugs, and making a few adjustments, it will bog now when i hold at a steady RPM, and blip the throtle. I noted the values before I monkeyed around, and even after I changed them back, it keeps bogging.
Now I have 108 miles on the motor now, so I don't really want to have it tuned by an expert, than have to go right back in a couple months for load tuning, and pay twice.
Old Nov 4, 2003 | 02:34 AM
Chris Ng's Avatar
I'm with stupid -----^
DO you have fuel cut on deceleration turned on? if so, turn it off and see if the bogging goes away.. if it does go away, then chances are you have some lean spots in your map as well as increasing pump 2 will help.. but turn off the fuel cut on decel first...
Old Nov 4, 2003 | 03:26 PM
10sec rx7's Avatar
you will need to add the settings in the load map, the idle map only works when the throttle is closed
just start it up and add 10% to the mixtrim and see if that fixes the bogging, if it does it is too lean, and you will have to add fuel to the maps.
Dale
Old Nov 4, 2003 | 09:52 PM
thanks a ton.
Adding fuel to the mixtrim fixed teh bog. adding a little fuel to the load map got it even smoother.
Old Nov 4, 2003 | 10:39 PM
10sec rx7's Avatar
execlent,
just add some more fuel to the idle and load points so you can but the mixtrim back to 0%
Dale
Old Nov 4, 2003 | 10:41 PM
rx7_turbo2's Avatar
Professor D.P
Originally posted by 10sec rx7
execlent,
Dale
I find myself using the mixtrm alot. It's a good tool, use it to determine what the engine wants, then make the adjustments in the map and put the mixtrm back to zero.
Old Nov 5, 2003 | 04:04 PM
cool, I'll give that a shot tonight.
Old Nov 7, 2003 | 12:13 AM
ok, to get the car running good, I had to add 22% with the mix trim. However, I am getting some surging at constant throttle.
Since I went up 20% with the mix trim, do I go up 22% of the values on the load map? to get the mix trim back to 0.
Old Nov 9, 2003 | 04:28 PM
10sec rx7's Avatar
the surging at part throttle is probably too lean, just add the 22% to the values and then add some more to get rid of the surging in the 20 and 15" screens
Dale
Old Nov 10, 2003 | 10:00 PM
OK, I'll give that a shot tomarrow. Let you know how it goes.
Is it normal to have to add this much fuel for a street port? I have stock injectors.
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
