rear wiper not working
Old Nov 1, 2003 | 07:06 PM
RitcheyRch's Avatar
Did a search and could not find anything.
As you can see my rear wiper is not working and I can not figure out why. I checked the fuse and it was not blown. I think the switch is still good because when I push it I can hear the washer pump working.
Any ideas.
Rich
Old Nov 1, 2003 | 07:15 PM
K-Tune's Avatar
FD Daily
rip it off! weight reduction and better aerodynamics
Old Nov 1, 2003 | 07:22 PM
RitcheyRch's Avatar
I would like it to work. I thought about taking it off but then figure might as well leave it on.
Old Nov 1, 2003 | 07:38 PM
mazdaverx713b's Avatar
Have RX-7, will restore
get a voltmeter and see if the motor is getting power. also do the same for the switch if you may suspect it could be at fault. if power is there then the motor may be faulty.
Old Nov 1, 2003 | 07:45 PM
RitcheyRch's Avatar
I know power is getting to the back since the washer is working and when I touched the switch on the rear strut I got spark.
Old Nov 1, 2003 | 07:58 PM
maybe look into replacing the wiper motor. thats all i could think of off hand.they get corroded on the inside from sitting. when they work, you will appreciate it. i really do!!! some say its a novelty, but who cares. it works and it'll help with rain and snow (if you dare).
Old Nov 1, 2003 | 08:21 PM
RitcheyRch's Avatar
If the motor is shot where can I get another one
Old Nov 1, 2003 | 08:47 PM
prob any parts store. if you aren't ready to fork out a little cash, maybe check ebay for a good deal or try searching the forum for one or put in a request in the parts for sale/wanted section. i'm sure someone has one. if i did, i would gladly hook you up. we all share the same sickness here and i really don't think anyone here is out to JUST make money selling their parts here.
Old Nov 1, 2003 | 09:31 PM
erick1120's Avatar
The wires for the washer pump are not ran in the same location as the ones for the wiper motor. Have you looked at the setup on the passenger side strut. It might be corroded or broken. One of my friends found this was the only reason his didn't work. We just re-wired it from the expandable cord part down to the motor box.
Old Nov 1, 2003 | 09:36 PM
RitcheyRch's Avatar
I funky looking setup does look like it has some corrosion and when I tried scraping it off it sparked on me. I will pull the fuse and sand the connections.
Old Nov 1, 2003 | 09:39 PM
Critoris's Avatar
Is the wiper supposed to return to the up position on its own? Mine never has.
Old Nov 2, 2003 | 12:46 AM
Suparslinc's Avatar
It's Back!
I tried to buy one off partstrader and the guy wanted about $100. So I said screw that I'll just let it rust.
I think from the bad seals on the hatch they tend to go bad.
Old Nov 2, 2003 | 01:12 AM
Manntis's Avatar
add to cart
NO. 80's cars ended in the down postion, 90's cars ended in the up position. Not a hard rule, but generally true.
Old Nov 2, 2003 | 12:01 PM
Critoris's Avatar
Mine's never returned to anything. Is it supposed to keep running after you turn it off until it goes al the way down?
Old Nov 2, 2003 | 12:46 PM
Manntis's Avatar
add to cart
Yes it is.
Old Nov 2, 2003 | 11:19 PM
BrianHeston's Avatar
Beware Of Squirrely Wrath
I already posted this reply once, but it has apparently disappeared.
RR - Possibly check the fuse to the rear defrost. These two circuits are linked.
Critoris - Mine returns to the down position, after switching it off.
Later,
Brian
Old Nov 3, 2003 | 04:55 AM
RitcheyRch's Avatar
MY rear defrost does work so it seems the fuse is still good.
I will check for power this afternoon if it doesnt rain.
Old Nov 3, 2003 | 06:00 AM
mwpayne's Avatar
Admitted 'rexaholic'
My rear wiper stops where it is when I turn off the switch.
What controls that?
Old Nov 3, 2003 | 09:16 AM
anthrax's Avatar
Heck Yes!
The connection that actually delivers power to the wiper is only in contact when the hatch is closed. these contacts are only point contact and can become dirty and not work all that well.
Or the assembly can slip too far away for the contacts to make poperly.
So there is no confusion this is the round plastic assembly at the "top" of the right side (pasenger side) hatch strut.
I have to adjust mine every couple of months because of my Subs the vibration causes the assembly to move out of place.
I would look at this befor I got into replacing the motor because if this does not work your new motor will not either
best of luck
A
Old Nov 3, 2003 | 09:37 AM
RitcheyRch's Avatar
I was going to clean the contacts at the same time as checking for power. I sure hope it is just some dirty contacts and not a bad motor
best of luck
A
Old Nov 3, 2003 | 10:54 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
I've got a rear wiper motor I'd sell. PM me if interested.
Old Nov 3, 2003 | 10:57 AM
anthrax's Avatar
Heck Yes!
the other thing you can try is turning the tube that the connector is attached to. That worked for me for a while.
I am having the same problem again myself
Old Nov 3, 2003 | 11:05 AM
RitcheyRch's Avatar
Let me make sure it is the culprit and if I do need one I will discuss it with you
Old Nov 3, 2003 | 11:51 AM
Im going to have to agree with FBdrifter.... granted, its probably because i bought my car from a junkyard, but anything that didn't work (back wiper, ac, ect..) got yanked...
Old Nov 13, 2003 | 08:59 PM
RitcheyRch's Avatar
Well got it figured out. The wiper motor is good. The connector that has the screw adjustment on it was not coming into contact with the other part.
