Fuel injectors for a 35/40 setup
Old Oct 30, 2003 | 08:28 PM
65Imp's Avatar
Performance Part Purveyor
I currently have stock 550 primaries, and 1300 secondaries. I see two feasable options to upgrade my fuel setup to safely accomodate the 35/40 kit I'm installing:
1. Sell the 1300's, get custom rails and 1600 (or 1680) secondaries.
2. Keep the current 1300 secondaries and go with 850 primaries. Also I'd likely need a FPR plumbed into the stock rail.
Any thoughts, reccommendations? It's generally a street car, and reliability is the primary concern. Also have the denso fuel pump. Not planning more than 450 rwhp. thanks for the input fellas.
Old Oct 30, 2003 | 08:35 PM
Broken09's Avatar
I am becoming...
Currently I'm running 550 primarys with the 1600's secondaries with aeromotive fpr. No problems thus far.
-Nic
Old Oct 31, 2003 | 03:10 PM
you will be fine with 1300cc setup.
Old Oct 31, 2003 | 03:42 PM
Jesuscookies's Avatar
I can haz rotary?
I'm running 850's front and back at 360RWHP, no problems.
check out maxcoopers web site for a good fuel calculator. What you have should be fine.
Old Nov 1, 2003 | 11:27 AM
IRPerformance's Avatar
Sponsor
problem with the 1300s is that they are enlarged 850s and have a figh falure rate
Old Nov 1, 2003 | 03:51 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Experiment seven is correct. The 1300cc injectors are 850's that are bored out. They do have a fairly high failure rate just like alot of other automotive parts that are bored out to allow for more flow. Look at piston engines that get huge bore out jobs. They are never as strong as the original cylinder wall. Where the 1600cc injectors are a stock Bosch part and they are extremely reliable. Just something to think about.
Zach
Old Nov 4, 2003 | 12:22 PM
apneablue's Avatar
I haven't installed my GT35/40 kit yet but I have a Bosch 750 Primaries and 1600 Secondaries with a supra pump. I was told it would be good for my goal which is 400-425.
Old Nov 4, 2003 | 01:31 PM
the_glass_man's Avatar
Will u do me a kindness?
While they are enlarged 850's, I have yet to see any physical evidence or real proof to support this theory. Always hearsay.
Old Nov 6, 2003 | 03:12 PM
BoostedRex's Avatar
I have seen them fail on a couple of motors. One of them happened to be a bridgeported 20B!! Talk about a serious waste of a beautiful engine. That thing blew up like a fire cracker on the 4th of July. The others I saw were all on 13B-REWs. There wre only 3 injectors that I have seen fail. However, 3 is MORE than enough. Just my experience though.
Zach
Old Nov 8, 2003 | 07:04 PM
suprfast's Avatar
from what i recall the high failure rate is caused by poor parts in the first place. we send RC our 550's wanting 850's. well the 550's are cracked worn out and some parts just cant be replaced. imagine going to mazda and buying a new injector then sending it to RC. results should be better. waste of money if you ask me though. i would just get a custom fuel rail and run bosch injectors all the way. more fuel, cheaper...
kris
82streetracer
Aug 23, 2015 09:28 AM
86rxNa
Aug 11, 2015 11:51 AM
