How can I reduce voltage in a line. What do I use
Old Oct 30, 2003 | 03:05 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
Im trying to set up a 2 stage voltage switch for my fuel pump. Its a Aeromotive a700 (I do not have the money for a fuel pump controller).
what should I use to bring the voltage down, and any idea how much I should drop it?
Old Oct 30, 2003 | 03:27 PM
nillahcaz's Avatar
you are missed
use a variable resistor and a DMM to set it.
as for a control do you want it rpm controlled, throttle, or speed?
PS i can make a diagram for all 3 so let me know.
is this a 1st,2nd,or 3rd gen?
Old Oct 30, 2003 | 03:44 PM
hmmm? I was going to use a switch but a refernced auto switch would be nice.
a boost switch would probably be the best. and simplest to hook up.
this is a 82 S with a 91 JDM 13bt. T04b
Old Oct 30, 2003 | 05:10 PM
nillahcaz's Avatar
you are missed
i called a local dist. about a presure switch for you i will find you the price and tell you.
Old Oct 30, 2003 | 06:27 PM
rockshox's Avatar
the resistor needs to have a very high power rating. about 120w. a regular variable resistor will not do. i would just use a stock fuel pump resistor from an FD. you also dont need those diodes in the above diagram.
Old Oct 30, 2003 | 07:18 PM
nillahcaz's Avatar
you are missed
sorry about the diodes i I started with a low voltage transistor circuit i made some time back and didn't think to get rid of them. I did not remember till you brought it up but FC TII had a fuel pump resistor as well. this should be found at a junk yard. it is under the air box in the front passenger side of the engine bay.
ps. it is a white "by now off white" block that is about .25"x.25"x1"
if your not that good at soldering i will make it for you at cost + shipping.
Old Oct 31, 2003 | 04:19 AM
InsaneGideon's Avatar
Still on 1st engine
In our EE power lab at school we have a few 10A-rated pots. They're wirewound and a tad larger than the wheel on my FD.
This is why the variable FP controllers use PWM. Come to think of it, I think the RX-8's pump is PWM controlled.
Old Oct 31, 2003 | 11:28 AM
nillahcaz's Avatar
you are missed
I can make a pwm controler... But i have no clue to the cost. i have never made one for 12v that will take 15 amp, I do know how. i just dont know the price.
Old Oct 31, 2003 | 06:33 PM
chairchild's Avatar
50mpg - oooooh yeah!
Why not get some old sub voice coils and (after working out what value you need) arrange them in different configurations to get the correct resistance/current flow ability
Old Oct 31, 2003 | 09:40 PM
rockshox's Avatar
sigh. i dont know even know where to begin on that. coils are inductors and inductors are for AC not DC.
Old Oct 31, 2003 | 11:07 PM
Still on 1st engine
nillahcaz, you're going to need a single big MOSFET. Probably less than $8 for one that can withstand the flyback voltage from the FP motor. Other than that, the little parts (a 555 or what have you) shouldn't run more than $10 for a homebrew.
Old Nov 1, 2003 | 01:27 AM
nillahcaz's Avatar
you are missed
i was thinking a LM324n quad op-amp
78L12 volt reg
and irf521 mosfet
plus some parts i "can but wont" get from radio shack
i would say i could probly get it to your door for $25-30
. i just have not had time to call gateway elc.
i will let you know sat or monday.
also InsaneGideon. do you think i should put a cap on the DC pulse out to help make it a a constant voltage rather than a pulse? i don't know if the pulse could "would" make the brushes in the pump spark. this is assuming it is not a brush less motor. nice mini
Old Nov 1, 2003 | 02:11 AM
Still on 1st engine
Alright, someone noticed the Mini! The logo at the top of the clevage says "FHM"... in case anybody was wondering.
Yea, good call. The cap will help reduce EMI emitted from the flyback current, especialy if it's close to the motor on the harness. Kinda like a condenser-cap on a distributor. I'm remembering my R/C days when the little motors had little disc capacitors soldered directly across the motor's terminals. If they weren't there, the radio electronics would go nuts. It'd definitely have to be a high volt cap.
Watch out for the 7812. They require more than 12V to keep regulating (Like at least 13-14V). If the "12V" car power really dips to 12V strange things might happen. Maybe try a 7809 instead, and run the opamp at a 9V instead. Or use a Zener diode to regulate opamp power. This is assuming you plan to feed the MOSFET the unregulated B+.
Old Nov 1, 2003 | 01:50 PM
nillahcaz's Avatar
you are missed
thanks for the heads up about the 7812. i was told it was good to 11v.
82streetracer has not replied so this may turn in to a project for me
Old Nov 1, 2003 | 05:26 PM
sorry, forgot about this thread.
I was down at radio shack the other day trying to figure this out. they didnt have any pressure switches. Im looking for a switch that turns on as soon as there is boost.
Old Nov 2, 2003 | 02:49 AM
Still on 1st engine
Try calling a NAPA store... I believe they have pressure switches. You can probably find an adjustable one there, actually.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
WANKfactor
Sep 29, 2015 01:14 PM
rattlehead
Sep 25, 2015 10:55 PM
