how do I get to the rear axle seal?
I have never worked on drum brakes before, and I started to today. I need to change a seal, and I can't figure it out. I got a chiltons manual, but its a p.o.s. as far as I can tell, its not specific at all.... There is a hub type of thing that seems to be attached to the axle, and I imagine I need to get inbehind that but I am not sure how, and the manual doesn't specify this.... any1 know about what I am talking about? Thanks.
Heres the entire Factory Service Manual on line. ENjoy.
http://www.wankel.net/~krwright/cars/rx7/85_manual.html
http://www.wankel.net/~krwright/cars/rx7/80_manual.html
the axel seal is held on by a pressed on retaining sleve. the sleve has to be cut and broken into 2 parts then u can press off the seal and bearing. i bent a axel the 1st time i tryed to get the bearing off. most shops charge about 15$ to remove install the parts from the axel.
No sure what he is doing.
I remove all the drum brake parts, backing plate and the four bolts that fasten it to the axle. You pull the axle shaft out, sometimes a slide hammer puller is needed, i just tap the axle shaft out with a rubber mallet. Once the axle shaft is out, remove the seal from the axle housing with a screw driver to pop it out.
John
John
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
