Wheel bearings and brake rotors
Old Oct 1, 2001 | 10:15 AM
Pele's Avatar
Right near Malloy
The wheel bearing is integrated with the brake rotor, right?
So, if I buy new brake rotors, will I get bearings aready in them or will I have to get bearings seperately, pack the grease myself, and press them in myself?
I don't hve a bearing press, I don't think a hammer or teh bottom of my shoe counts either.
Old Oct 1, 2001 | 12:48 PM
P.O.S. Racing's Avatar
Normally don’t get bearings with new rotors.
You’ll probably need to press in the inter and outer bearing races on the new rotors, they are the only item pressed into the rotor. You’ll need to pack the bearings with grease.
And don’t forget the dust seals!
Wish I had my Haynes manual handy so I could provide more technical info.
Old Oct 1, 2001 | 06:52 PM
Pele's Avatar
Right near Malloy
I have both the Haynes and Factory book. I can see how they go together, I was just wondering if they were sold together as some calipers are sold with pads.
Old Oct 1, 2001 | 09:31 PM
Denny's Avatar
Bearings are sold separately, pardners. There's very little pressing involved. Tighten the axle nut until you feel drag when you spin the rotor, then back off a bit.
Denny, from the 'ol corncrib...
Old Oct 1, 2001 | 09:46 PM
jrx13's Avatar
If you buy new bearings, they come with new races so you just have to install those instead of hitting your old ones out of the old rotors.
fidelity101
13
Aug 31, 2015 07:47 PM
RaY358
Aug 19, 2015 11:44 PM
Marty RE
Aug 17, 2015 09:36 AM
