Power FC I installed 1300cc injectors into Power FC..........
Old Oct 16, 2003 | 12:25 AM
Dragonz818's Avatar
I dont know exactly what to put in the commander? I obviously put 1300 at the bottom but I am not sure what else has to be changed.
I can really use some help guys. The car is making a wheezing noise as well. Has good vacuum though so I am trying to figure out the problem.
Thanks- Jerry
Old Oct 16, 2003 | 12:40 AM
Fd3BOOST's Avatar
Recovering Milkaholic
Whoa, you need to stop playing around and do some reading man or your next post will be detailng how your mtor just blew and now you hate rotaries casue they are so unreliable.
I belive that you can find some help in the ECU discussion areas. I think that there are some base maps. Also go here and at least get a manual so you can have some sort of clue as to what you need to do.http://www.scuderiaciriani.com/rx7/
Add it to your favorites if the server is down and go there later if you have to.
Old Oct 16, 2003 | 12:44 AM
Dragonz818's Avatar
Thanks for the help I was hoping that someone who installed these before could just tell me whats need. Just for the injector part of the FC. Im not trying to tune the whole car.
If anyone who has 1300cc injectors and programmed it themslef could help out that would be really helpful.
Old Oct 17, 2003 | 08:12 PM
duboisr's Avatar
You need the injector lag time programed in . PM Rotorbrain for imfo .
Old Oct 17, 2003 | 11:20 PM
cewrx7r1's Avatar
Eye In The Sky
DRAGONZ818,
You sure have a lazy attiude! Grow up!
Old Oct 18, 2003 | 07:40 AM
kempo's Avatar
i have mine at .16. but you should do a search on the pfc forum to double check
Old Oct 30, 2003 | 08:22 PM
Ranzo's Avatar
Download the manual........Read it It explains how to figure the lag time or rather gives lag times for common injector sizes then you can get close.
For the secondaries just change the injector size and lag time. No need to adjust the percentage, the PFC does it automatically for the secondaries. I am not sure of the Lag time for 1600 CC injectors.
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
