5th Gear Problem
Old Sep 29, 2001 | 03:01 AM
RyanC's Avatar
5th Gear Problem
If I am having trouble getting into 5th gear does that mean that the synchro is going bad or could it be something else. There is no grinding just trouble getting into the gear. It seems that most people who need a new 5th gear synchro have had grinding problems. Just wondering if anyone has any information on this kind of problem. Thanks.
Old Sep 29, 2001 | 01:36 PM
i'd say the synchro is ur problem....mine does the same thing but it hasnt gotten any worse for about the last 30k mi or so. expensive fix too.
Old Sep 29, 2001 | 02:32 PM
rxrx7's Avatar
That's what it sounds like to me. PM Cpunla, I think he had the same problem.
Old Sep 29, 2001 | 08:08 PM
3rdgenowner's Avatar
Actually its not THAT expensive, I think KDRotary does it for around $450 or something
Old Sep 29, 2001 | 08:14 PM
Nike178's Avatar
for $450 u can buy a used tranny with low miles and in good shape.
Old Sep 29, 2001 | 08:18 PM
Id sure like to know where.........
Old Sep 30, 2001 | 05:29 PM
JspecFD's Avatar
If you've got a '93 with a VIN# lower than ~10530, then your tranny was built with the weaker 5th gear synchro. As long as its not grinding, the synchro should still be ok but be careful since its a known weak point.
Old Oct 1, 2001 | 08:28 PM
Rx7aholic's Avatar
Hey in a week or 2 from this week I will be doing my clutch and doing the recall on the 5th gear synchro> My 5th gear does the same thing too. Anyhow I will let u all know how it turn out.
Old Oct 2, 2001 | 12:43 AM
RyanC's Avatar
Your going to do the 5th gear synchro recall yourself? I have heard it is quite a job. I am interested to see how it goes. Good luck.
Old Oct 2, 2001 | 09:07 PM
Rx7aholic's Avatar
Hey Ryan c, yes it's a big job I was hoping to do in two weeks but I will have to put it off later this winter or next year, The reason is because I am in the middle of buying a house and closing is by end of this month. Anyhow I was looking at the shop manual today and according to book it look like I will have to buy mazda sst tool inorder to do the job Or I can go it around it most of time I really don't use mazda sst tool. Also I won't recommend this task if u do not have the shop manual, I Have the one that mazda mechanic use at the dealer and plus all other books for the 3rd gen.
rgordon1979
40
Mar 15, 2022 12:04 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
sinistersam
Sep 13, 2015 07:17 PM
