Fuel pump rewire for N/A...
Old Sep 28, 2001 | 02:57 PM
MasteRX's Avatar
More Than Meets the Eye
Question Fuel pump rewire for N/A...
Okay, I pland to rewire the fuel pump for my N/A. I have heard that N/A cars dont change the voltage at idle like Turbo cars do. Is this true? If I wanted to rewire the fuel pump, could I just send a 12 guage wire and relay to the back and have the old power for the fuel pump engage the relay? Or should I still move the stock relays and such? Anyone have a good writeup on a N/A specific fuel pump rewire? Thanks.
Old Nov 21, 2001 | 03:04 PM
supergoat's Avatar
Eggs are like fowl cheese
To the top.
I plan on doing this over thanksgiving holiday. Where is a good write up on this. Hopefully it will fix my big power drop at 3800rpm.
Old Nov 21, 2001 | 07:01 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Re: Fuel pump rewire for N/A...
[QUOTE]If I wanted to rewire the fuel pump, could I just send a 12 guage wire and relay to the back and have the old power for the fuel pump engage the relay?[QUOTE]
that is exacly what you need to do, just make sure you have a fuse near the battery on the wire.
Old Nov 21, 2001 | 07:03 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Originally posted by supergoat
To the top.
I don't think that has anything to do with it. add a ground from the battery to body. and one from body to engine. you might also have to reground the ecu and boost sensor.
Old Nov 21, 2001 | 10:04 PM
HAILERS's Avatar
HAILERS
N/A do not have the voltage drop, so why would you want to do it? Puzzled.
Old Nov 22, 2001 | 09:57 PM
tesla042's Avatar
I hear that this has helped with the mysterious left hand turn fuel cutout... as well as replacing the in-tank filter.
Old Nov 22, 2001 | 10:04 PM
supergoat's Avatar
The boost sensor has been reground
I have a ground from the battery to engine, but not engine to body....I'll do that tomarrow
Aramir
Sep 8, 2015 08:21 PM
