Fuel cut off switch
Old Oct 7, 2003 | 11:42 PM
Fuel cut off switch
Has anyone done it themselves before or know how exactly to do it?
Old Oct 7, 2003 | 11:48 PM
rxtasy3's Avatar
U need a simple on/off toggle switch(SPST). If ur pump is like mine, single hot wire with pump to ground, run a wire from 12+ to one terminal of switch, the other terminal of switch to pump. The switch just completes the circuit.
Old Oct 8, 2003 | 06:32 PM
skunks's Avatar
I'm a CF and poop smith
get a gravity sensor which will kill fuel pump if the car flips over or if there is an impact. you can get this at pegasus racing.
good luck
P.S. you can install a manual one too but make sure not to put it in the cabin, fuel spraying at you in an accident is the last thing you want!
alphawolff
Nov 17, 2015 05:57 PM
armans
Aug 15, 2015 09:08 PM
