DLIDFIS update still working it
Old Sep 30, 2003 | 08:36 AM
seanrot's Avatar
Always waiting for parts!
Pictures
Well, I have made the coil rack and the ignitor rack. You can see in the pictures. You are probably going to notice that the ignitor rack is a little small. But, I was running out of aluminum and I figured its directly behind the fan so it should be, OK. Also, I cant hook it up yet, do to a dead fuel pump problem on the 7.
Get this, I came home late the other night and didnt close the door completely on the daily driver. So when I got up and went outside to do some arrands the battery was dead. I figured just move the 7 around to the other side of the car so I could jump the battery. The 7 started up fine, backed out of the spot no prob. when to drive into the other parking spot, sputter sputter engine died. So, now I push it forward into the spot. Hook up the cables and let it sit while I trouble shoot. Poured a little gas in the carb she fired right over. I figuring fuel deliver problem. So I disconect the fuel line to the carb put it in a bottle try to start the engine and nothing.. Well, I left it at that. will go out on my days off and complete the trouble shooting.
So anyways does the DLIDFIS set up look like its coming alone good?
