Cheap Grounding System, worth it??
Old Sep 28, 2003 | 05:01 PM
volley1's Avatar
Grounding System
What do you think of this grounding system? I went to home depot today to make my own grounding system and it cost me like 28 bucks for all the wire and connectors. I returned all the stuff because I remembered seeing this one on ebay. The cables are pre-built and it is cheaper than the home depot stuff. Is this kit worth it?? Thanks.
Old Sep 28, 2003 | 07:24 PM
GsrSol's Avatar
Z06 powered FD
For $20 I don't think you could go wrong.
Old Sep 28, 2003 | 08:31 PM
cpa7man's Avatar
Racing is life!
Looks ok, but the cables don't appear to be very long. I spent about $20 as well buying wire & connecters.
Old Sep 29, 2003 | 06:44 AM
rxrotary2_7's Avatar
yeah i would say yes. you would most likely spend about $20 on cable and ends anyway. you dont have to use that *circle* they supply. but the only thing is that shipping on it was almost as much as the item.... now you are not talking $20 anymore, you are talking close to $40.... and that i would say is up to you. do you want to save about $20 and DIY, or would you rather pay $20 and have it "done for you" thats my $.02
Old Sep 29, 2003 | 04:26 PM
FormerPorscheGuy's Avatar
Yes it is for sale.
I did mine with wire and end caps from Home Depot for right around $20. It works great.
Old Sep 29, 2003 | 04:46 PM
I was wondering if there is a picture wirte up (DIY) of grounding somewhere on the web??
Old Sep 29, 2003 | 05:44 PM
RotorJoe's Avatar
Hooray For Boobies!!!
The only thing I realy agree with is the noise from the stereo ground. The rest is a little bit of a stretch. Also this system is only as good as the main ground that you connect to that. Make sure the connection is to bare metal then treat it with a dielectric grease. It would be good to have though, so you can plug more electrical systems/components in later (like a distrubution block).
Old Sep 29, 2003 | 07:20 PM
volley1's Avatar
https://www.rx7club.com/forum/showth...ighlight=hyper
This is the link to the Damian thread on Grounding points.
rgordon1979
40
Mar 15, 2022 12:04 PM
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
alemmons
Sep 4, 2015 09:34 AM
