Biggest width tire on a FD!
Old Sep 26, 2003 | 08:28 AM
RX-Racer's Avatar
Aoohh!!!
Whats the widest tire you can fit on a fd?
Thankz,
JP
Old Sep 26, 2003 | 10:04 AM
crazysuprakid's Avatar
On stock wheels, OEM is 225/50/16, you can run 245/45/16 also easily. I know people will run a lot larger size drag radials on the OEM wheels. With aftermarket wheels I think you can run 315's in the rear with 2.5 coilovers. But it requires the fenders to be rolled.
Hopefully someone with some real world experience will reply.
Old Sep 26, 2003 | 10:12 AM
RX-Racer's Avatar
Aoohh!!!
Well im looking for wide tires for a drag tire. I have 18" rims.
Jp
Old Sep 26, 2003 | 11:10 AM
rynberg's Avatar
If you are serious about drag racing enough to get tires for it, you don't run 18" wheels. Stick some BFG drag tires on the stock 16" rims and you're good to go.
If you are REALLY serious about drag racing, then you would already know the best setup and wouldn't have to ask....
Old Sep 26, 2003 | 11:11 AM
redrotorR1's Avatar
LS6 Convert
On an 18x11 rim, you can fit 335's in the rear. It does require 2.5" ID coil springs and aftermarket toe links and trailing arms ... and a little fender rolling. For a less expensive option ... 285's on a 18x10 or 18x9.5 rim.
Old Sep 26, 2003 | 11:52 AM
RX-Racer's Avatar
Aoohh!!!
K, Thankz for the size.
JP
Old Sep 29, 2003 | 05:55 PM
BATMAN's Avatar
I run a 255 ft and 275 rear on 40 ratio for 17's
since my front fenders are rolled I can run a 275 in the ft.
Old Sep 29, 2003 | 06:33 PM
ZoomZoom's Avatar
SEMI-PRO
I run 285-30-18 S-03 Pole Positions on the back. Not bad but dont hold the power from a launch . Hops too much too. get some Stock wheels with Some Mickey Thompson ET Streets. Use them at the TRACK ONLY. Will hold like a *****. Launch at 6-7k rpms. Good luck.
Old Oct 2, 2003 | 07:47 PM
racer1's Avatar
flying apex seal
without wide body kit or anchors rear 275will be fine...285 maybe too much....of course there comes RE Amemiya with wide side skirt-anchors or you buy a wide bodykit if you need more
Old Oct 3, 2003 | 06:49 AM
maxcooper's Avatar
WWFSMD
As others have said, low profile tires don't work well for drag racing. I'd get some street tires for your 18"s and get a pair of stock wheels with drag slicks on them for the strip.
-Max
Old Oct 6, 2003 | 01:45 AM
reza's Avatar
How about for autocross? Can we fit 18x10.5 or 18.11 in the rear? What would the offset be? I think more than +50?
So run 18x10 +52 offset front, and 18x11 +?? offset rear? CCWs?
Old Oct 6, 2003 | 12:25 PM
SleepR1's Avatar
Note that 7.75 inches is the most rear wheel position back space you can run WITH M2 trailing arms. 7.5 inches back space is max for stock trailing arms. Thus 11 x 18 in back (really 12 x 18, add 1 extra inch for overall width), you'll need rolled rear fender lips (if you go with 295/30-18s). The rear front space ends up being 4.25 inches, and offset is 1.75 inches (~45 mm) with 11 x 18s. If you don't have really bad understeer, the upside is the car will look awesome with 295 meats in back
Old Oct 6, 2003 | 03:41 PM
reza's Avatar
Well, if you have coilover and enough ride height, you will be able to do it without rolling the fender right?
Reza
Old Oct 6, 2003 | 03:45 PM
SleepR1's Avatar
Nope. The 2.5-inch coil springs and M2 trailing arms buy you 0.25 inches more clearance on the inside to fit wider wheels fr/rr, but the excess still has to stick out, cuz your maximum back space is fixed at 7.75 inches in back and 7.5 inches up front.
Old Oct 9, 2003 | 03:41 AM
Node's Avatar
BATMAN, could you post pics of your rolled front fenders
Old Oct 10, 2003 | 01:13 AM
turbojeff's Avatar
Do it right, do it once
Spank has 335s in the rear with Petit flares I believe.
Old Oct 15, 2003 | 04:30 PM
RX-Racer's Avatar
Aoohh!!!
I want to see some pics of those!
JP
rx7jocke
72
Jun 17, 2016 03:48 AM
