please help
Old Sep 24, 2003 | 09:34 PM
RX7obsessed's Avatar
Newbie
please help
hi i finally was able to get a 93 mazda rx7r1 with 53,000 miles on it,so far its running amazeing.The only thing that seems wrong is when its at idle.Its at its normal idle at 800 but when i start revving the engine it will rev up but when it goes down it goes below 800 for a little bit and almost feels like its gonna stall and then go back to 800 and be normal.is this something i should worry about?Please respond because i just spent 14,000 on it.thanks
Old Sep 24, 2003 | 09:39 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
*EDIT* Sorry... I was being an *******. I'll see what I can dig up.
Old Sep 24, 2003 | 09:41 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
https://www.rx7club.com/forum/showth...=Idle+gremlins
Old Sep 24, 2003 | 09:44 PM
911GT2's Avatar
The Power of 1.3
If it idles at all, you're doing good in my book.
Old Sep 25, 2003 | 12:49 AM
T88NosRx7's Avatar
hmmm....bad idle, I would get it checked out if I were you.
Old Sep 25, 2003 | 01:09 AM
rynberg's Avatar
Check your TPS voltages to make sure they're in spec.
Old Sep 25, 2003 | 01:39 AM
BigIslandSevens's Avatar
Change the spark plugs,fuel filter(if you can afford it),check the condition of the air filter/s. If dirty replce or clean as needed. These small things can affect idle quite a bit. ( plus it's something you can do,...plugs are easy at least....and relativly cheap.) It may be a clogged cat. But try the plugs and stuff first. Good luck!!
Old Sep 25, 2003 | 02:27 AM
Garrett's Avatar
Might be your grounding. Make sure your grounding connections are clean.
