Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Max duty cycle with Pettit ECU?
Old Sep 23, 2003 | 12:04 AM
RexTech's Avatar
Arrow Max duty cycle with Pettit ECU?
I have a pettit ecu -the limited one- i would like to know what is the max duty cycle for it and the max for ther unlimited one.
thanks,
RT.
some mods:
*Pettit street ported engine.
*dp, mp, apexi muffler.
*Pettit high flow turbos -single configuration-.
*Boost: 10 lbs. -controlled by greddy profec b-.
*J&$ knock sensor.
Old Sep 23, 2003 | 06:50 AM
Mahjik's Avatar
Mr. Links
I'm not sure what you are after. The Pettit ECU's can run the stock injectors at 100%. However, that's doesn't mean it's a good idea. As long as all your fuel components are in working order and your A/F ratio is in tolerance, then it's not a problem.
However, if your injectors are not flowing as much as they should, then the duty cycle won't necessarily reflect the amount of fuel being used.
msilvia
15
Sep 11, 2015 12:13 PM
mulcryant
Sep 9, 2015 05:24 PM
nkuhajda
Sep 7, 2015 04:07 PM
