Driveshaft Puzzle
Old Sep 21, 2003 | 12:40 PM
gxlbiscuit's Avatar
DONT FEED THE NOOBS
Driveshaft Puzzle
here is the deally..... i have a turbo2 tranny(A) with a N/a manual rear end(B). how do i get point A to B without buying the rear of a t2?
Old Sep 21, 2003 | 02:42 PM
marcus219's Avatar
FC Mobsta
This is what I'm going to do.....was informed by a member from teamfc3s.com
Get a Turbo II driveshaft and a Turbo II diff. flange....I guess the only thing that makes the TII driveshaft not fit is that the flange is bigger, so you take the n/a flange and the TII flange to a local machine shop, have them machine the TII flange to the size of the n/a one.
-Marc
Old Sep 21, 2003 | 03:14 PM
Aaron Cake's Avatar
Engine, Not Motor
Any driveline shop can make you a custom shaft.
Old Sep 21, 2003 | 04:43 PM
Scott 89t2's Avatar
SOLD THE RX-7!
best way
Old Sep 21, 2003 | 04:56 PM
Evil Aviator's Avatar
Rotorhead
Mazdatrix will also sell you their replaceable u-joint driveshaft with mis-matched parts so you can use a TII transmission with an NA differential.
Personally, I would recommend just pulling the rear subframe from a junkyard TII. Then you will have the stronger differential and halfshafts, too.
It is probably best to buy a new driveshaft no matter what you choose, as the orginals are all pretty much shot at this age.
Old Sep 22, 2003 | 07:50 PM
gxlbiscuit's Avatar
DONT FEED THE NOOBS
this is probably a dumb question but how much should i expect to pay? at a driveline shop... t2 junkyard cars are rare here i need a working car
series1rx7
Sep 27, 2015 05:46 PM
