HELP - Secondary turbo boost problem ??
Old Sep 21, 2003 | 07:51 AM
cruiser's Avatar
I installed M2 stage3 ECU on Friday and did a trackday yesterday, running about 10-11psi on the track. I got home and everything was fine. Few hours back I took the car to the carwash and was still fine. After I took it out of the carwash and came to piece of straight (after few minutes), I accelerated to redline and got some secondary boost problems - primary boost is fine then at transition it falls to 8psi then keeps falling to redline (and the car feels weak) whereas it was fine just 30minutes ago.
My boost was fine before, also I got no smoke out of exhaust during boosting.
Any hints on what could it be ?
Old Sep 21, 2003 | 08:00 AM
Mahjik's Avatar
Mr. Links
Check for a blown off vacuum line...
Old Sep 21, 2003 | 08:32 AM
cruiser's Avatar
Which lines to check - On the actuators or under the UIM ?
Old Sep 21, 2003 | 08:46 AM
Mahjik's Avatar
Mr. Links
I would start with the ones on the firewall side of the UIM. Do a quick check for the line to the pressure chamber with the check valve on it.
Basically, just open the hood and start looking around.
Old Sep 21, 2003 | 10:44 AM
cruiser's Avatar
Found it !
It was the hose that comes on the black box in front of the UIM Dunno what the box is calles though.
Old Sep 21, 2003 | 10:49 AM
SleepR1's Avatar
Originally posted by cruiser
Found it !
Pressure chamber...so a hose was disconnected from there?
Old Sep 21, 2003 | 01:48 PM
cruiser's Avatar
Yes, the front hose was disconnected. I still have stock hoses. I know I know... I need to do the silicone hose job, but as long as she's running I can't find time to do it
cristoDathird
28
May 30, 2019 08:47 PM
Kyo
Apr 13, 2019 09:24 AM
Wolf_
Aug 11, 2015 04:23 PM
