Need help, engine might be gone!!!!
Old Sep 19, 2003 | 08:37 PM
Newbie
Unhappy Need help, engine might be gone!!!!
my engine is doing this weird noise like if it was restricted first i thought it was the cat that was clogged up so i took it out and it still does it, than i thought it was wit the full and it still does it, so i did a compression check and the fron one was ok, but i got no compression from the back at all, does that mean i blew an apex seal?
Old Sep 19, 2003 | 09:29 PM
Turblown's Avatar
Turn up the boost
No compression means you blew an apex seal. Pray your rotor housing isn't fuxored. I'm in the same boat, another $800 down the drain..
Rotary Performance Parts
Old Sep 20, 2003 | 07:51 AM
mfinn's Avatar
Newbie
have you tried the atf treatment, blew a engine last year,it was dead used the treatment and car strarted right up, go to www.mazspeed.com; under facts go to atf treatment, good luck
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
