6 ports not opening and the ACV?
Old Sep 19, 2003 | 08:03 AM
abarlas's Avatar
sometimes I can feel the ports open when I hit 3800rpm, but other times I don't feel the ports open. Same driving condition. Could the problem be with the ACV? I was thinking I was not getting air into the air pipe which leads to the cat.
Old Sep 19, 2003 | 09:06 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Ok how does the ACV put the air into the ports? It is exhaust back pressure that activates your S4's auxilary(5th and 6th) ports. I would suggest checking for freedom of movement on the rods and sleeves. If they won't move easily then get to cleaning them.
Santiago
PS-Check out AZ Tech in my sig
Old Sep 19, 2003 | 09:48 AM
abarlas's Avatar
the ports move freely.
Old Sep 19, 2003 | 09:51 AM
1987RX7guy's Avatar
Make sure everythin is hooked up properly the split air tube and the small line that goes to the ports themselves. Trust me the ACV has nothing to do with the s4 ports. MAX's car rungs fine with no ACV and just the pre-silencer hooked up to the SAP
Santiago
Old Sep 19, 2003 | 02:15 PM
abarlas's Avatar
Santiago
Thanks for the info. That's go to know. Still learning the RX-7. This forum ROCK!!!!
Old Sep 24, 2003 | 06:07 PM
Rexmanwolf's Avatar
Str8 Waggin
hey how would you clean the ports mine don't move for crap?? Or maybe im doing it wrong. Any help?? got 91 vert and ports don't work
Old Sep 24, 2003 | 07:49 PM
1987RX7guy's Avatar
Search for 5th and 6th ports or auxilary ports.
But in short. You remove the whole intake. Then you remove the sleeves and clean EVERYTHING sill it is spotless!!!!! Reverse the procedure and your done
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Clacor
Sep 11, 2015 08:36 PM
doritoloco
Sep 5, 2015 12:41 PM
