radiator problems!!
Old Sep 24, 2001 | 03:13 PM
bladeboy66's Avatar
Angry radiator problems!!
I need some help people!
I had a new radiator put in and when I shut her down I was getting coolant leaking. The guy pressure tested the radiaotr and said all was holding but that I should replace the radiator caps- both over the AST and the radiator cap- I went and got 2 caps both with 16 pounds and put them on- still having the same problem- cannot see the leak. Does the rx require a cap higher than 16 pounds- the one on it prior to replacement also said 16 but it was not stock either- can someone look this up please? any other advise?
-Jon
94 montego blue
Old Sep 25, 2001 | 04:23 PM
Silver7's Avatar
where is the coolant leaking from? I don't think your problem is in the caps. Have you checked the water pump?
vmerino
Sep 5, 2015 11:26 AM
