Haltech ASAP Haltech Install Questions
Old Sep 23, 2001 | 11:56 PM
Rx_treme's Avatar
hey guys just about done with the haltech install and i have a few final questions before i can finish.
1) for the ignition I only have one plug left that is a four wire like the manual says and the colors dont match what the manual says. it has the following colors in it and they are 2 on top of 2.
TAN wire with WHITE STRIPE
GREEN wire with YELLOW STRIPE
RED wire with YELLOW STRIPE
Tan wire solid
the weatherproofing is a LIGHT GREEN.
thats the only plug i can think of or see that is fine to hook up to the CAS.
2) i'm just running the second orange wire that is flying back to the fuel pump. is this all right, since the other will hook to the battery?
other than those two things, it is going pretty much flawless. thanks
JASON
Old Sep 24, 2001 | 09:46 AM
tims's Avatar
I don't have my wiring diagram at work, but the plug for the CAS is easy to determine. it should be more than 4 wires(i think it is six) it is easy to spot as it contains a shielded cable(shieled wire is very small diameter with gray cover) with 2 or three additional wires. look for the connecter that has the shielded cable as well as some individual wires. fuel pump wiring is OK.
Old Sep 24, 2001 | 09:04 PM
tims's Avatar
it is J16 plug in the Haltech manual. this is connected to the CAS.
CAS........J16 haltech
red........yellow
wht/blk....blue
wht........red
green......green
blk and gry/red not used
Claudio RX-7
Haltech Forum
Apr 23, 2019 02:50 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
