Power FC How does the PFC control idle?
Old Sep 10, 2003 | 07:50 AM
moehler's Avatar
Question How does the PFC control idle?
I don't know anything about this, so please bear with me. There are three idle settings in the PFC (normal, electric, and a/c). When my lights are on or the a/c is on the car idles at the exact rpm that is set in the PFC. The "normal" idle, however, never idles at the setting in the PFC. It's always higher. Why would the PFC be able to control the electric and a/c settings so accurately, but not the normal setting?
Also, I've tried adusting the two idle screws and all that. The idle will hold to a good value (800-850) for a day or two then go back up to 950-1050. Thanks for any advice.
-Matt
Old Sep 10, 2003 | 12:55 PM
cewrx7r1's Avatar
Eye In The Sky
Usually that means the engine is getting too much air, but you said you tried adjusting both idle screws.
Try resetting the PFC; or turn O2 idle control off, adjust
the mixture for the middle or lean side of the range, then try idle with O2 off and on.
Maybe your ISC solenoid needs cleaning. If never done, it is sure to be very dirty and maybe sticking.
Old Sep 10, 2003 | 03:05 PM
moehler's Avatar
Where do you adjust the O2 idle control? Also, what is the ISC selenoid? Is this what the PFC (or any ECU) uses to control the idle? Thanks.
Old Sep 10, 2003 | 06:22 PM
moehler's Avatar
Nevermind... I got it. It was the air-adjusting screw. I though I had it tightened, but it never truely was. I finaly took off the elbow and made sure it was tightened all the way. Idle is perfect 750.
Old Sep 10, 2003 | 07:35 PM
cewrx7r1's Avatar
Eye In The Sky
Idle Speed Control = ISC.
I suggest you religiously study your Mazda maintenance manual, mainly section F. This covers all engine control systems.
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
imitek
Aug 28, 2015 05:28 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
