ajustable coils ???
Old Sep 2, 2003 | 05:18 PM
WanKeL FD RX-7's Avatar
Rotary addict since 86
ajustable coils ???
I have a 83 GS, i would like to drop it more... I have Tokico Blues with springs, but, i heard ground control makes adjustable springs for the FB, but is it for the GSL-SE or it can fit on all FB models ? If not, what can i do to lower the car a little bit.
Max
Old Sep 2, 2003 | 06:56 PM
JIMMY54's Avatar
GSL-SE PRO
I have the ground control set up. It works on any FB. Basically what you have to do is cut the stock spring perch and weld in a new one for the coil over set up to sit on. Beware though, you will need to get wheel spacers if you aren't running the stock rims because it will rub if your running somthing different.
If your springs have an area of "dead" coils you can cut them there without affecting spring rates.
Old Sep 2, 2003 | 08:07 PM
thanks Jimmy
RuffRx7
Oct 1, 2015 03:08 AM
GKW
Sep 28, 2015 04:34 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
