83 GSL and 84-85 SE Brakes SAME or NOT?
I was wondering if the 4 wheel disc brakes on the 83 gsl and 84-85 SE were the same or if the 84-85 were slightly larger. Also if anybody knows, are the brakes also swappable?
You can switch the whole system if you have the capabilities and the tools and with maybe a few very small modifications.
It pretty much bolts right in.
And then, of course, youll have to switch the rear out too. heh.
Since getting my -SE running and rolling i've learned that the clutch master and the brake masters ARE different from the rest of the models. There close, but different. The swap IS do-able, with some work though.
the lug pattern will be different too.
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
