High Idle, Poor reponce, any advice, please?? L@@K!!11&&##
Old Sep 1, 2003 | 12:21 AM
wagondriver69's Avatar
Thumbs down High Idle, Poor reponce, any advice, please?? L@@K!!11&&##
Hello all
Im having some carb problems (i believe) with my 12a GSL. It idles around 2000 RPM, and when I give it gas and let off, it sort of hangs at whatever RPM i revved to, and then backs down, and overall isnt that reponsive. I thought it was the clogged cats, but it continues to do so after deleting them. Its still gotits emissions ****, i was wondering if removing some of that could help, or does something just need an adjust?
Thanks,
Jeff B
Old Sep 1, 2003 | 12:51 AM
The_7's Avatar
Registered Piston Eater
maybe a vacuum leak, if you dont have emissions testing, i would remove the rats nest
Old Sep 1, 2003 | 02:35 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Yeah it's most likely a vacuum leak. Check all your lines, especially the ones leading to the carb.
Old Sep 1, 2003 | 05:24 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
I would take a look at your linkage, too. Just make sure it's all moving smoothly.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
risingsunroof82
Sep 7, 2015 01:11 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
