need help with amp install
Old Aug 20, 2003 | 08:27 PM
nakedky's Avatar
hey everyone, i need some help getting the power lines running from the battery to the amps. i cant seem to find a hole that works well to run the cords. i will drill if i have to, but ihad to do that in my last car and it was a BITCH! neway, thnx for your input.
Old Aug 20, 2003 | 11:35 PM
2manytickets's Avatar
what car are you working on?
Old Aug 21, 2003 | 05:07 PM
SERIES7's Avatar
Embassador to SOY
If it's an FD, there's a nice space on the passenger side I remember seeing when I installed my AVC-R. You should be able to slide a pair of 2 gauge wires through there with some effort.
Old Aug 21, 2003 | 06:58 PM
Quickfini's Avatar
I actually JUST installed my 12" sub and amp, and if you remove the driver side fender liner, you can see a big rubber plug that you can use to run your power wire.
Old Aug 22, 2003 | 12:59 PM
moehler's Avatar
I just had one wire to run, and I ran it through the streering column boot. It took two minutes.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
t-von
Sep 10, 2015 01:56 PM
Enzo1944
Sep 6, 2015 08:57 AM
