NSX rims fit a FD?
Old Aug 13, 2003 | 02:56 AM
c00lduke's Avatar
NSX rims fit a FD?
Like title says, just need to know.
Thanks
~Luke
Old Aug 13, 2003 | 03:54 AM
LoveBone's Avatar
Registered Sex Offender
Yes sir, they will.
Old Aug 13, 2003 | 11:02 AM
rynberg's Avatar
Originally posted by LoveBone
Yes sir, they will.
The majority of NSX wheels (94-01) were 16x7 +55 fronts, 17x8.5 +60 rears. I believe the new ones (02+) are 17x7 and 17x9, with the same offsets.
Therefore, only the 02+ rears would be an upgrade and they have too high an offset (may not clear brake calipers in front either).
So, I doubt they would fit....
Old Aug 13, 2003 | 12:09 PM
LoveBone's Avatar
The bolt pattern is correct. I've seen FDs run wheels with a 50mm offset. Would the extra 5mm (< 1/5") make that much of a difference? You can also use spacers, no?
Old Aug 13, 2003 | 02:56 PM
rfreeman27's Avatar
that offest is too high.
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
