Purge Control Valve = PCV?
Old Sep 16, 2001 | 12:49 PM
Flying Monkey's Avatar
I just replaced the vac lines on my 87 TII & finally removed the vac spiders. The purge control valve is bad. The diaphragm inside under the spring has a hole in it. Now, this looks like it does the same thing a PCV valve would on a piston motor. You have 2 lines run to vac signal & one that connects to the "crankcase". The 2 lines are reference signals, correct & the valve is basically just a check valve that allow the crankcase to vent back into the intake. Am I tracking correctly on this so far? The Mazda part is like $45. A Fram PCV valve is maybe $3 at Wal-Mart. Has anyone replaced the Purge Control Valve with a PCV valve? If so, any idea what the brand/part # was?
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
