HELP.. car won't run for more than 3 or 4 seconds
Old Jul 29, 2003 | 05:53 PM
87GXLRX7's Avatar
The following was removed:
Omp
Air pump
AC
Cold start Ast.
Emission control (on the side of the Lower Intake)
The Upper and Lower intakes were slightly ported
It seems to start fine, rev's up a little bit to about 3000rpm, than dies, if i give it gas it hesitates a bit and some times backfires a little.
any ideas
Old Jul 29, 2003 | 05:54 PM
87GXLRX7's Avatar
Oh Ya thanks for your time!
Old Jul 29, 2003 | 06:44 PM
WTF
that is a vac leak man..you forgot to cap somethng check the 3 vac lines on the back of the manifold near the fire wall, and the 3 vac lines right by the omp
Old Jul 29, 2003 | 06:49 PM
87GXLRX7's Avatar
yea i am pretty sure i have check the vac lines.. thanks though.. well i'm goin back to take it all apart off again
Old Jul 29, 2003 | 06:50 PM
SureShot's Avatar
Seduced by the DARK SIDE
Maybe a loose AFM connector?
Any check code?
Old Jul 29, 2003 | 06:53 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
check the AFM. That is the problem I had with my car not idling at all. It might have been shaken loose by accident or maybe a vac line popped off by chance. Check the AFM first alot easier to check that than vac leaks.
Old Jul 29, 2003 | 07:14 PM
87GXLRX7's Avatar
well thanks.. i got it figured out.. nothing major.. just a leaky UIM
87GXLRX7's Avatar
thanks guys..
Old Jul 29, 2003 | 07:22 PM
good job and congratulations
alphawolff
Nov 17, 2015 05:57 PM
highspeedrider
Aug 19, 2015 03:44 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
