AIC people or people high fuel people
Old Sep 14, 2001 | 06:17 PM
Want2race's Avatar
Bigger and better things
Anyone using this ?
I was thinking of having some of these made...
$200 is the rate and they angle downward...
Any comments or issues?
Old Sep 14, 2001 | 08:40 PM
13BAce's Avatar
On a long vacation
That's one nice piece. It looks like it's for an FD, right?
Old Sep 14, 2001 | 08:41 PM
13BAce's Avatar
On a long vacation
Does it come with the fuel rail?
Old Sep 14, 2001 | 09:03 PM
crispeed's Avatar
'Tuna'
It's a very nice piece but I see one problem with the design!
Looking at the bolt pattern on the plate it would position the injectors on the outside of the manifold right above the turbo or in the general area of alot of heat. Plus the fuel in the rail is sure to boil in that position not to mention the life of the injectors and o-rings might fail leading to a potential fire!
I've seen that set-up before but the injectors were place on the opposite side under the intake!
crispeed
87TII
9.20@150mph
Old Sep 14, 2001 | 10:33 PM
Want2race's Avatar
Yes it includes the rails.
It could easily be machined to fit under the manifold. I have no problem with its location and you could change the o rings @ a 15,000 mile interval with no problems whatso ever!
Mounting it under the manifold makes it both harder to access and service. The turbo also doesnt create that much heat. The unit would be ok for 60,000 miles of VERY HIGH HEAT! Most single turbos are vented downwards (because of their placement) so the air is drafted downward and out!
Old Sep 15, 2001 | 04:30 PM
soul assassin's Avatar
GTR eater
i think it would be way better off with it unnder the manifold, pulling the manifold takes a whopping 10 minutes. anyone that will be using that will have a upgraded turbine and i know my t04r would cook that thing in a matter of days
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
