Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Hatech and Ignition
Old Jul 19, 2003 | 05:46 PM
MOSTIN's Avatar
Hatech and Ignition
Have any body run a fuel only haltech with the stock ignition in the FD?
Do you have to remove the wire harness even it you dont need it?
Old Jul 20, 2003 | 11:36 PM
rxrotary2_7's Avatar
do you mean swapping a FC front cover on it and using that CAS?
what is it you are trying to do? are you running a F9/F10?
Old Jul 21, 2003 | 10:09 AM
Cosmo Donk's Avatar
Queer
I think he means just using the Haltech as a fuel controller and then using the stock ECU for the ignition. I don't know if the FD will like the stock injector connectors not being connected to anything but maybe you just have to jumper them or something.
Do you have to remove the harness??? No, you can leave everything in there if you really want to
Old Jul 21, 2003 | 09:30 PM
MOSTIN's Avatar
Yes I was planning on leaving in the wire harness to power the ignition circuit, for right now the only thing that the stock computer is powering is the two primary injectors ignition and oil metering pump, that brings me to the next question:
Will the oil metering pump still operate and where does it gets its signal from? crank trigger?
Old Jul 29, 2003 | 06:30 PM
RETed's Avatar
Pull the FI leads, install 15-ohm 20W resistors over them and be done with.
Wire the Haltech in parallel with the stock ignition input and TPS.&nbsp Wire the Haltech to handle just the fuel injectors and the MAP sensor input.
Don't touch anything else.
The stock ECU will handle everything but the FI.&nbsp The Haltech will merrily run just the FI.
-Ted
WANKfactor
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
