fitment question...
Old Jul 16, 2003 | 01:49 PM
rjuge's Avatar
this week i'm driving...
fitment question...
Will 18x9 rims fit a stock height 94 rx7?
Next, what's the best rubber without rubbin. What is the best size? 245/40?, 235/45?
Thanks,
Rob
Old Jul 16, 2003 | 08:28 PM
ARD T2's Avatar
OK. You must indicate the offset, wheel type. You can run 255/35/18 if offset is good.
I need to know what suspensio you got too.
Rishie
Old Jul 16, 2003 | 08:39 PM
Cheers!'s Avatar
Former Rx7 *****
rishie,
what is the ultimate widest tires and rims u can fit on a FC?
brad apold runs 17x9 +35 mm offset on a 235 tire (not sure of aspect ratio) and a 17x10 265 tire (again not sure of aspect ratio), with Enkei RPF1
can u comment on this fitment?
i would assume he is running a 235/40/17 tire, what is the benfit if fitting a 235 tire on a 9 inch rim versus a 8 inch rim?
Old Jul 17, 2003 | 02:34 AM
ARD T2's Avatar
I don't know how he's doing it? I am more conservative on my max fitments.
I'd say 8 up front with 235/40. I'm unsure of and advantage. Depends i guess on the type of racing being done.
Rishie
Old Jul 17, 2003 | 08:03 AM
Cheers!'s Avatar
Former Rx7 *****
rishie so 235/40/17 will work on the front? with a 35 mm offet?
because i came across this thread:
http://www.teamfc3s.org/forum/showth...threadid=14219
and with a 40 mm offset 235/40/17 rubs
renjiv2
57
Jan 25, 2024 03:34 AM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Turblown
Sep 30, 2015 05:58 PM
imitek
Sep 22, 2015 11:29 PM
