Sponsored by: CARiD
joints leaking?
Old Jul 14, 2003 | 11:28 PM
93redFD's Avatar
joints leaking?
Im done installing my motor and today I tried to fix the my problem from friday. WhenI prime the fuel pump gas would leak out from the front of the fuel rail(banjo joint). I sanded the copper washer to make them like new and put some extra turqe to it and teflon sealant. Now they dont leak as bad but I can tell that its leaking. It doesnt drip, but If I rub my fingers across the joints I have gas on my fingers. Sence its such a small leak can I use some kinda of "fix a leak". I was at advanced auto and saw something that for leaking things, it was gas / alch resistance. Would this be ok? Or no that **** never works. I will be checking things often, 2 times a day.
Old Jul 15, 2003 | 03:21 AM
Project84's Avatar
Open up! Search Warrant!
With gas leaking, you never want to take a chance. Replace the cooper washer, and if necessary, the banjo bolt. If there is a slight amount of fuel getting through now, what will happen as time goes on? Trouble always happens at the most inconvenient time. You should play it safe.
Old Jul 15, 2003 | 08:18 AM
kyle@insight's Avatar
Dont like it? I dont care
I agree. Gas = fire = no mo FD
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
joel(PA)
Oct 4, 2015 06:07 PM
series1rx7
Sep 27, 2015 05:46 PM
