Power window doesn't work
Old Jul 10, 2003 | 05:42 PM
Suparslinc's Avatar
It's Back!
I was fiddling around with the switches, since the pass. side stopped working right months ago, and I think i shorted something out on the passenger switch because there was an arc.
Now both windows are dead. I can't get the drivers side to go up; I checked the obvious fuse looks good. I could use any advice at all, it's impracticle to drive the car with one window stuck down and the other up.
Old Jul 10, 2003 | 05:56 PM
vic'srx-7's Avatar
Check the switches they are **** and could have broken when they shorted out . While you have them out you can check to see if there is power to the switch. If there is the switches are fucked. Go to radio shack and get a couple of replacements and wire them in.
Vic
Old Jul 10, 2003 | 06:22 PM
enigma32's Avatar
You can fix the stock switches too.... it's a pain in the ***, but just pull 'em apart and clean the contacts
Old Jul 10, 2003 | 06:45 PM
Suparslinc's Avatar
It's Back!
I'm not getting any power to the switches. Could it be another fuse? Fusible link?
Old Jul 10, 2003 | 06:49 PM
13B4port's Avatar
Will Work for Beer
yea. chekc under the hood on the drivers side. same thing happened to me when i got my car. all the wiring was fucked up bad. and battary acid was all of ther engine bay along with the shot engine. all the fusible links were bad. i replaced them and all the stuff works fine now.
Old Jul 10, 2003 | 06:55 PM
Suparslinc's Avatar
It's Back!
Strange it turns out it was the 15 amp DEFOG fuse that was blown. Replaced it with a spare that was in the fuse box and the window works fine.
Now lets see if I can fix the passenger switch
bURGRotary87
Aug 19, 2015 03:54 AM
