Sponsored by: CARiD
Idle adjustment
Old Jun 30, 2003 | 07:57 AM
Newbie
Question Idle adjustment
The fast idle works just fine, but when the car warms up the rpms drop below 500 and the engine stalls. What is the best way to turn the normal idle up. I see in the manual info. on fuel mixture and var. resistor, but I don't want to mess things up worse.
Old Jun 30, 2003 | 12:25 PM
Cosmo Donk's Avatar
Queer
Well, one fix that is easy to do and is gauranteed to raise your idle is the throttle stop screw Pretty hard to describe it but it is a set screw on the firewall side of the TB (Turbo version, front side NA). It is really small and is where the throttle rod has an attachment that hits this little screw which opens the throttle more. It has an 8mm nut on the other side of it to stop it from backing out.
Hope this helps
DerpyToast
14
Nov 23, 2024 05:19 PM
Microtech
Nov 21, 2015 10:20 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
