damnit another problem
Old Sep 9, 2001 | 08:03 PM
4cefed7's Avatar
Here is the deal.
2 weeks ago car would not start, sprayed carb cleaner into throttle body, it starts.
Ever since then it has had starting problems.
Before anyone write it off as compression, it was able to only lose to a 500+ rwhp supra by about 4-6 cars from 70-160mph.
Drove fine Saturday(hit 160mph again with same Supra).
Parked it, came out to start it again(only off for about 10min) would not start. Spray in carb cleaner again, get it to start.
The only problem is that it is smoking like a big dog
You can hit boost in 1st, 2nd sometimes, no way in the top 3 gears. It just sputters. Idle is fine, has good vacume, makes good power if you can get it in boost. Plugs are 2 weeks old, they appear to be fine, both coils are firing.
Other symptoms
open the oil cap, and it smokes
backfires alot, i mean loud *** backfires.
Just registered for NOPI, now my car is messed up
car is far from stock, check homepage for mods
Old Sep 10, 2001 | 01:08 AM
Keith's Avatar
Unhappy
Sounds to me like your oil control seals on your rotors are bad. This would explain the oil smoke, and under boost you could be oil fouling your plugs. Either that, or the boost problem could be another problem, like an injector with a bad spray pattern or clogged orifice, bad ignition wires, etc..
Irv, Keith's dad
Old Sep 10, 2001 | 03:31 PM
ShadowClown's Avatar
my car was makin loudass backfires, flames, spluttering and really hard to start, turned out to be a boost hose under the BAC its only about 10 cm long but mine was split ....soon as i replace the hose it was better than ever
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
