Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
A'Pexi or Microtech
Old Jun 23, 2003 | 01:28 PM
A'Pexi or Microtech
Are these two fuel computers different? It seems like the S-AFC is a piggy back setup and the Microtech is more a Stand Alone setup. Am I right?
I do plan on purchasing one or the other. So i m just looking for input on both. Does one system do more than the other or are they similar.
and by the way money isnt a concern. i just want to knoe if they compare as far as tuning is concered
Old Jun 23, 2003 | 07:49 PM
10sec rx7's Avatar
As far as im aware the sfac is only a fuel controller that mods the fuel flow of the standard ecu,
the microtech is a full replacment ecu that controls both fuel and ignation and you no longer have to have the standard ecu in the car,
if you have a FD there is a plug and play version of the microtech.
Dale
Old Jun 23, 2003 | 09:20 PM
so as far as tuning is concerened I would have more capability with Microtech?
Old Jun 24, 2003 | 12:58 AM
HIMNI Racing's Avatar
Rick James
I thought yer A'PEXi 7....................
I'm just jokeing.
Yeah......what he ^^^ said.
Old Jun 24, 2003 | 01:03 AM
Rick James
Yep, that's right.
The two aren't even the same. It's not even fair to the S-afc to be compaired w/ the Microtech.
It's like a big wheel racing a RX-7.
Old Jun 24, 2003 | 01:25 AM
10sec rx7's Avatar
Yes you will have heaps more tunability with the microtech, the biggest advantage is you will be able to change your ignitian timing with a sfac you cant change it.
Dale
Old Jun 24, 2003 | 11:02 AM
well thats all i need 2 knoe..........im guessin it would be just plain stupid to hook up both right?
sorry i asked but it was just a thought
mike
Old Jun 24, 2003 | 04:50 PM
No7Yet's Avatar
The S-AFC alters the airflow meter signal to trick the ECU into injecting more or less fuel.
With a Microtech, you don't have an AFM at all.
Brandon
BR7 Racing
Old Jun 29, 2003 | 10:44 PM
so with the microtech system will i be able to adjust how much fuel is going the engine?????
Old Jun 29, 2003 | 10:49 PM
and i heard the microtech system can adjust the rev limiter to 9k and sometymes 11k........is that BS or the truth?????
mike
Old Jun 30, 2003 | 04:09 PM
Fishy's Avatar
Question with the Microtech, does it control boost properly or do I have to use a boost controller?
Mike, from my limited knowledge of the MicroTech, yes you can control the fuelling and the RPM limit.
Dan
Old Jun 30, 2003 | 06:00 PM
10sec rx7's Avatar
apexi7,
yes you can control how much fuel goes into the motor,
you can set the rev limit to where ever you want, any where from 0rpm to 16,000 rpm
you can have boost control setup on the microtech to use a standard s4/5 type soloniod
Dale
Old Jul 7, 2003 | 04:32 AM
Chronos's Avatar
wrong thread
Old Jul 7, 2003 | 12:18 PM
fatboy7's Avatar
Got Boost?
Apex'i PFC is a better comparison with Microtech, but only with all the optional equipment, like the commander and datalogit. Of course at twice the cost.....
eddierotary
16
Oct 4, 2016 08:22 PM
frijol
Microtech
Sep 23, 2015 12:51 PM
freq
Haltech Forum
Sep 13, 2015 07:45 AM
