just bought single turbo/need help with tune up!!!
Old Jun 18, 2003 | 11:26 AM
1badd7's Avatar
Just got a 93 rx7 with the to4s single turbo. Need help with a tune up!!! I have the power fc w/commander, blitz intercooler, twin power ignition, 850/1600 injectors, and 3mm w/port and polished engine.
I need help trying to find out what kind and # to use for the spark plugs. Do I use the same for all four??? I want to go with a colder plug.
I pulled the old ones out and two were ngk and the other two were champions??? Should I go with those, because he got them tuned with those and had no problems?
Any input would help. Thanks you!!!!!!
Old Jun 18, 2003 | 11:45 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
when I had that setup I think the best way to go... (kinda expensive) is w/ 9's in the leading and 11-11.5 in the trailing... just depends... check w/ your tuner if you have one and see what they say.
Old Jun 18, 2003 | 02:57 PM
rx7racer11's Avatar
i heard you should run 9's all the way around..
Old Jun 19, 2003 | 07:16 PM
Badog's Avatar
Use platinum 9's with a copper crush washer. That washer is worth half a heat range. If they toast out too quickly, go colder.
Skeese
65
Mar 28, 2017 03:30 PM
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
Wolf_
Aug 11, 2015 04:23 PM
