will this rrfpr work?
Old Jun 11, 2003 | 08:55 PM
FB II's Avatar
http://store.summitracing.com/partde...rt=AEI%2D13202
i'm using it on my turbo carb project. 12a not 13b. hahaha
Old Jun 11, 2003 | 09:43 PM
mechgod's Avatar
Building Motors
How much fuel pressure do you need?
Old Jun 11, 2003 | 11:56 PM
FB II's Avatar
not fully sure yet. i just know i need it to work with atleast 8 lbs of boost on a carb'd motor.
Old Jun 12, 2003 | 12:34 AM
web777's Avatar
Yes, it'll work but you still need a fuel pump.
Old Jun 12, 2003 | 12:38 AM
Pedestrian X's Avatar
SpAz!
yes, that should be more then enough.
Old Jun 12, 2003 | 01:23 AM
fatboy7's Avatar
Got Boost?
That's not a RRFPR. In the description it says "Features include a 1:1 pressure rise when referencing boost." By definition, a Rising Rate Fuel Pressure Regulator was a rising rate, ie (2:1, 3:1, 5:1, etc.). All FPRs reference manifold pressure, so almost all will work for both turbo and non turbo. (Note: there is usually a limit to the highest manifold pressure that it can handle, this one handles up to 25 lbs)
But you don't want a RRFPR, that what getto EFI turbo setups use, when they can't properly tune the engine to run the boost they want. Carbs can't use a RRFPR, period. They'd overflow the float bowls every time you hit boost.
Old Jun 12, 2003 | 02:43 PM
Turbo12A's Avatar
Then what would you use for a turbo fb? Not the stock fuel system???
Old Jun 12, 2003 | 02:56 PM
pillage6's Avatar
I would have to disagree with you fatboy7.
What are you basing your opinion on?
I have a turbocharged carbeurated car with a RRFPR and have never had a problem with overflowing the float bowls.
maikelc
Aug 24, 2015 11:04 AM
