Clutch Question -- ASAP
Old Jun 10, 2003 | 03:32 PM
neoamd's Avatar
LS Powered
when the throw out beairng grabs on the clutch ring should the collar slide with the throw out or should it stay in place?
My throw out is sliding the collar with it.. crazy..
If not what should I do to fix it?
Josh
neoamd's Avatar
LS Powered
Also everytime I turn the key (just to wire up my boost gauge for light) i smell gas. what the hell!?
Josh
Old Jun 10, 2003 | 03:35 PM
BMike's Avatar
in the cabin or in the engine bay? turning the key to full ON without starting still runs the fuel pump so if you have a leak you'll dump some fuel out...has your car had the fuel line/pulsation dampner recall done?
neoamd's Avatar
LS Powered
out side of it..
Nope.
Josh
Old Jun 10, 2003 | 03:46 PM
BMike's Avatar
If the car never had the recall done, id suspect that as a prime candidate for whats causing the smell, you should get it to a dealer to get that fixed or DIY cuz it can lead to the old engine fire o doom.
Old Jun 10, 2003 | 04:57 PM
Mahjik's Avatar
Mr. Links
Re: Clutch Question -- ASAP
Josh
Is your clutch working (ie, can you put the car through the gears)? If it's working, don't mess with it (IMO). If it's not working, well.....
The collar should be anchored in the pressure plate and extented onto the collar. It should never be flat against the pressure plate for operation (or else the throw-out bearing can/will pop out). Pushing the collar into the pressure plate is what allows the throw-out bearing to be unattached (for dropping the tranny).
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
