Accessory that turns on at idle???
Old Jun 10, 2003 | 01:25 AM
SyderJL's Avatar
EMPEROR
Question Accessory that turns on at idle???
Hey guys, I am sick of the annoying sound that my airpump makes!! I know that it is easy to disingage but it will cause a lumpy idle if it is not engaged during idle.
I want to know if there is an accessory that gets power(switches on) when the clutch is engaged?
I want to know so I can relay the airpump electrical connector to this power source so that the airpump is only functioning when the car is at idle and will fix the lumpy idle problem.
I am just thinking. . . . . . .
good idea or bad??
Tell me what you think or if you know what wire to use!
Thanks
Justus
Old Jun 10, 2003 | 11:18 AM
FormerPorscheGuy's Avatar
Yes it is for sale.
Bad idea. You will clog your cat by doing this and potentially foul your car up with constant electrical gremlins. If you don't like your air pump and its set up, get a midpipe and remove the air pump.
Old Jun 10, 2003 | 12:12 PM
SyderJL's Avatar
EMPEROR
I know the dangers of clogging the cat. but it will still be active at idle if I set it up this way and otherwise the car should be running hot enough to compenstate(right?)
If thats not the case can you explain why it clogges the cat. I searched and searched and I cannot find any conclusions.
Thanks,
Justus
Old Jun 10, 2003 | 12:22 PM
Yes it is for sale.
Wrong. The air pump continuously forces air into the cat. If you shut it off above idle, your cat will not get air when it needs it the most. If you shut it off during driving you might as well remove it because you aren't doing a damn thing to help your car.
Old Jun 10, 2003 | 12:28 PM
SyderJL's Avatar
EMPEROR
ok, I guess I am just looking for an explination on what the airpump does to consevre the cat. By pushing air into the cat b/t idle and 3800 rpms how does this help keep the cat. from breaking down?? I thought the airpump was used to keep the emissions down when the car was cold.
Please help me make sense of its function
Thanks for the responses porscheGuy
Justus
Old Jun 10, 2003 | 12:40 PM
Yes it is for sale.
Your main cat works best when it is heated up. It helps control emissions during driving by burning excess hydro carbons that are released from your engine while it is running.
If you don't like it go with a midpipe setup, but this will not pass emissions. From when I have read on your other threads though you should be doing reliability mods first before your attempt this as it will require other upgrades.
Get a downpipe and keep your stock main cat until you are ready, or feel the need, to make the necessary upgrades for a midpipe.
Old Jun 10, 2003 | 12:46 PM
SyderJL's Avatar
EMPEROR
I can't go with a midpipe right now b/c of lack of mods preformed. Although I do plan on doing that in the distant future, right now I am looking for a good solution to elminate the airpump while driving without screwing up the car.
Your explination of the airpump is helpful, can you elaborate on why it will clog the cat. if it is discounted while driving(the cat. should be heated up while driving)
Thanks for the input!
Justus
Old Jun 10, 2003 | 12:54 PM
Yes it is for sale.
Originally posted by SyderJL
right now I am looking for a good solution to elminate the airpump while driving without screwing up the car.Justus
Here is the short answer. There isn't one.
Justus
The main cat needs fresh air to burn the hydrocarbons. The airpump provides this.
Why are you so insistant on removing your airpump?
What are you hoping to acomplish by doing this (other then blowing up your motor)?
Old Jun 10, 2003 | 01:14 PM
Street King's Avatar
*** Bless Texas!
The idle will be lumpy yes but nothing that is annoying. You can get rid of the air pump and cat and run a resistor so the ECU thinks the air pump is running I think. Other than that I don't see a way of keeping the main cat and not the air pump. I was always told the air pump only comes on at certian rpm's, like 1250-3675 rpms or somewhere around there.
Old Jun 10, 2003 | 02:47 PM
NewbernD's Avatar
Tequila? ..it's like beer
Re: Accessory that turns on at idle???
[B]Hey guys, I am sick of the annoying sound that my airpump makes!! I know that it is easy to disingage but it will cause a lumpy idle if it is not engaged during idle.
If it really is just the noise you object to ( that you can now hear with an aftermarket intake, I'm assuming??) you could just add a muffler to the airpump hose. One came with my old pettit intake. It was just a plastic chamber but it did muffle the honk/moo/noise a good bit. I've also heard of some intake scoming with restrictors for the air-pump hose that will accomplish the same thing.
Probably better than defeating it at this stage of the game.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
