rough idle and high pitched squeaking!
Old Jun 9, 2003 | 05:48 PM
steve's dog's Avatar
the other day i after i GOT MY OIL CHANGED, i noticed i had a somewhat rough idle (no big deal) (COULD it be do to AFM?) so i kept it running and poped the hood to look/listen. my friend told me to rev it up so i did. around 4k rpm there was this horrible high pitched squeak. to about 5.5-6k rpm. i thought, no big deal, when i did it agian there was nothing. so today i was going in first gear (not flooring it) and the same high pitched squeak happened. i wanted to know what could be causeing this and what can be done about it? and what it means?
Old Jun 9, 2003 | 06:07 PM
wow, has anyone even had this problem before?
Old Jun 9, 2003 | 06:11 PM
could be a blet or your heat shield . my heat chield was making a werd sound i thought it was the motor but no big deal takin it off when i get dp and cat replacement .
Old Jun 9, 2003 | 06:12 PM
Boost Lee's Avatar
Dark Lord of the Drift
i did... part of the flange on my BAC broke off.... so i had an intake leak on decel use some brake clean and see where you are leaking from!!
Old Jun 9, 2003 | 06:40 PM
mr_vaughn's Avatar
Chillin
check all yours belts. some oil may have gotten on to them and cuasing them to slip @ higher RPM
Old Jun 9, 2003 | 06:41 PM
zinx's Avatar
_________________________
Sounds like a worn belt, thay make some god awful banshee noises when they wear.
Old Jun 9, 2003 | 07:55 PM
zinx who ended up winning the drag races?
how much are replacment belts? or can i clean them if they have oil on them? i think i have a leak in the oil pan.
Old Jun 9, 2003 | 09:13 PM
zinx's Avatar
Some hick in a auto mirage or something that ran like a 12.00 every time, i think they should ban autos.
Belts are cheap, i went to advanced auto and picked up the alt, P/S and A/C belts for less than $15 (i think, its been awhile but i know they were cheap.) They are a piece of cake to replace too.
Old Jun 9, 2003 | 09:25 PM
Amur_'s Avatar
Refined Valley Dude
Use your ears. Where in the engine bay is the squeak coming from?
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
firzen
Sep 15, 2015 12:04 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
Skeeg
Sep 5, 2015 07:41 PM
