What rubber are you 400+rwhp guys running
Old Jun 8, 2003 | 05:42 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Mods - I know this isnt a single turbo question but I thought I'd get a better responce here. There arent as many 400rwhp+ guys in the suspension/tires area.
Ok, so with that out of the way....
I'm wondering what tires you guys with 400rwhp+ are running? Do you run Nitto Drag radials all the time? If so how are they when your just driving around iwth no burnout and nail the gas? Anyone running a normal street tire like a Bridgstone SO3 or similar? How do those do?
I'm fixing to buy tires, I'm probably going to get Nitto drag radials as my BFG drag radials only lasted me 5000 miles with NO burnouts lol. I'm just worried mostly about the rain factor and also wondering if some street tires like the SO3's would actually hook better than the Nittos on the street since I wont be doing a burnout.
Thanks,
STEPHEN
Old Jun 9, 2003 | 11:40 AM
SPOautos's Avatar
Damn, you mean non of you 400+rwhp guys have tires!!!!
STEPHEN
Old Jun 9, 2003 | 12:03 PM
Resource's Avatar
I've got Nittos 555R. They work great for street use. The only time you're going to beed to do a burnout is if you plan on going from a dig on the street. I do however pop them loose from 1st to 2nd ang then 2nd to 3rd but tire spin is minimal. I couldn't imagine using a regular street tire on the streets. Just too dangerous.
Old Jun 9, 2003 | 12:20 PM
nocab72's Avatar
03 Cobra Killer
current: Toyo Proxy T1-S's 255x35x18, I say no no no to them...
Waiting for my new wheels and going with the Nitto 555 Extreme II. Drag Radial compound, but has stiff sidewalls (road race tire) so you shouldn't sacrifice any cornering ability over street tires...biggest potential issue is that the Extreme II only comes in one size 275/40-17. Nitto rates them for 15k miles, I'll be happy with 1/2 that.
K
Old Jun 9, 2003 | 12:36 PM
TailHappy's Avatar
Addicted to Track
You might want to try Yokohama A032R's. They're basically a wet race tire. With a tread wear of 60, they're not quite as sticky as Victoracers (50) or Hoosers (0, I think). But they also have better wet weather traction and slightly higher wear. However, with monthly autocrosses, and about one track event per set, I'm only getting about 5000 miles (or less) out of them. They also roar fairly bad if that bothers you.
Old Jun 9, 2003 | 12:54 PM
Wargasm's Avatar
Weird Cat Man
I run Toyo RA-01 225/50 16 on my car...
They SUCK for drag racing due to super stiff sidewalls, but they are good for hard street driving or road course use.
They are NOT wide enough to make any use of 1st gear. Wheelspin the whole way. 2nd will spin them but not TOO badly that you can't keep your foot on it.
I'm going to swap those out for 245/45 16 street tires I think.
Brian
Old Jun 9, 2003 | 01:10 PM
IRPerformance's Avatar
Sponsor
I have minimal traction problems with Toyo T1-S 245/45/16 on stock wheels. I mean I do break them loose, but it not too bad. I think its mostly due to my suspension setup. I have the M2/AD coilovers. It hooks pretty well.
Old Jun 9, 2003 | 02:25 PM
maxcooper's Avatar
WWFSMD
I only got ~370 RWHP on the dyno (12.5 psi), but I've been running a few more psi since then (15-17 psi), so I'm probably over 400.
I run 265/40-17 S-03 tires on the back. They don't hold first gear at all, not even a little. I think you'd need one of those traction control systems to be able to run through first without mad wheel spin consistently. Almost all of the time, if I am going straight and the ground is not wet, cold, or I don't crest a bump in the road, they will hold through second. If they do break loose in second, the car usually keeps accelerating at a good pace (unlike first where they spin to oblivion immediately). Third holds even better, but they will break loose occasionally from hill-cresting, water, cold, whatever. I don't really shift hard, so I don't have a lot of info about traction at the shifts.
Are A-032Rs more sensitive to cold than more street-oriented tires? That wouldn't necessarily turn me off of them, but it is something to consider when making a purchase decision.
I often accidentally spin my 285/30-18 BFG R1A tires at the track when starting out from the pit lane. I'm not sure if it is the short sidewalls or that I am usually starting out on a lot of rocks and marbles. Probably the surface more than the tires. I should go try some launches with them on the street, I guess. They spin easier than I would have guessed from the debris-laden pit lane.
-Max
Old Jun 9, 2003 | 02:43 PM
RageRace's Avatar
I use Bridgestone Potenzas 275s. If you dont want to use drag radials, and have the most traction, you should get a wide rim with some over fenders and put some of those monster 315s that the vipers come with on there. My buddy has a Hennessey with 550 hp and he breaks them loose but Rxs will never see that knid of torque and i believe they would hold very nice. I believe the Banzai also uses this exact setup.
Old Jun 9, 2003 | 03:26 PM
artguy's Avatar
WTB** Very Low Miles 94-95
what size rims are you all running?
great question stephen...Im to that same point with my car. its tires and rims time. i cant keep the tires stuck on the road... Im running yokohama intermediates on stock rims.
j
Old Jun 9, 2003 | 06:15 PM
ZoomZoom's Avatar
SEMI-PRO
I get decent traction on the street during warmer days and when i have had some time to heat them up ( Not burning out just driving for a while) I run 285/30/18 Bridgestone S-03's on back. They rate about a 7 or 8 at best for traction for me. You can NOT launch hard on them or they will just Hop and spin into eternity but I have had some rolling starts full throttle in first gear without lighting them up. Its kinda tricky and would probably be better off with Nitto 555R's on back. Something wide.
Old Jun 9, 2003 | 07:01 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
whoa kyle..did u just get that 95 r33 skyline? what are the plans for it? Must be nice to have that much cash at your disposal.
Old Jun 9, 2003 | 08:16 PM
1FastT2's Avatar
Yoko AVS ES100's here. Im running a 265 35 18's in the rear. 1st and 2nd gear it rips them loose but for the most part there a pretty good tire for the price. Great handling.
Old Jun 10, 2003 | 08:42 AM
TailHappy's Avatar
Addicted to Track
I think the A032's are a little more sensitive to the cold. They definitely lose some traction on a cold morning, when the tire itself is also cold. By the same token, on a scorching day at the track, when driven hard, they can start getting greasy. But it's the best all-weather tire I've found so far.
Also, I just want to point out that you also have to really consider what you're after. From the ininitial post, drag racing wasn't specified (though now that I re-read, I guess it was hinted at), although the thread has gone that direction. If you do spirited street driving and "track" driving (which I consider a road course, not the dragstrip), then A032s are good due to their stiff sidewall and grip. If you prefer to spend your time racing in a straight line, the stiff sidewall makes them a bad choice because they don't buckle and spring back like a drag tire, and they aren't sticky when they're cold, which hurts you if you don't do a burnout. HTH.....
Old Jun 10, 2003 | 10:57 AM
SPOautos's Avatar
Awsome, I'm glad all you guys replied.
There is no chance of me getting larger wheels at this time, I'm in the middle of building a new house.
I think what I'm going to do is this....I'm going to run Nitto 555 Extreme Drag radials on the rear with a REALLY REALLY good rain tire up front. I hear the SO3's are a real good rain tire.
What do you guys think of that? Also, is anyone running the 245/50/16 Nitto Drag radial? Does the sidewall look way to big? The reason I ask is I've heard they are going to stop making the 225/50/16 and the only tire we'll be able to fit on the stocker is the 245/50
Thanks guys,
STEPHEN
Old Jun 10, 2003 | 11:50 AM
vosko's Avatar
Just Call Me Terminator!
i am running the 555R Extreme II's in 275/40/17 on my car right now. i like them alot! the handle pretty damn good and are VERY sticky. just driving it picks up every goddamn rock in the road. i have gotten a 1.82 60 FT on them also.... i like them alot. i also bought the tire warranty where i bought them from so when wear out.... i'm gonna have a blowout LOL
Old Jun 10, 2003 | 02:16 PM
finnicky7's Avatar
26.55 psi T04Z Monster
nitto tires
In regards to the Nitto 555R 225-50- R16, they stopped making these as far as I know quite recently. I have tried to find another set with no avail. But the the 245-50-R16 Nitto's look pretty good.
Old Jun 10, 2003 | 05:18 PM
ZoomZoom's Avatar
SEMI-PRO
Better do it before they wear out. They are Pro-rated and the amount you get is determined by the tread thats "unused" when they are damaged.
Old Jun 10, 2003 | 08:47 PM
rynberg's Avatar
Stephen, I think that's a very BAD idea. The reason being that, in the rain, you would want the better gripping tire in the rear, to make the car understeer. Otherwise your front end will be sticky with a tail that constantly wants to step out. (Actually, ideally, you would want ALL four tires to have the same grip but....)
Thanks guys,
STEPHEN
I don't think you can run a 245/50 up front, especially if you have a lowered suspension at all. A 245/50 16 tire is more than 3/4-inch taller than stock.
Old Jun 10, 2003 | 11:44 PM
SPOautos's Avatar
Yea, I was thinking of the SO3's in front in the stock size (225/50) with the Nittos in back with the only size I can get which is 245/50.
I know running a good rain tire ONLY up front isnt ideal but I only have so many options.
I pretty much HAVE to run drag radials on the back and there is only one size that I can get which is 245-50 no matter if its Nitto or BFG...thats it.
Then on the front I can either run a good rain tire or a not good rain tire. I can see where the set up might not be optimal but I'd imagine running the good rain tire will be better than a poor rain tire.
Might be wrong though, it wouldnt be the first time lol
STEPHEN
Old Jun 10, 2003 | 11:47 PM
LUV94RX7's Avatar
Oldie, but Goodie
Originally posted by SPOautos Yea, I was thinking of the SO3's in front in the stock size (225/50) with the Nittos in back with the only size I can get which is 245/50.I know running a good rain tire ONLY up front isnt ideal but I only have so many options.
STEPHEN
I have Nitto drag radials on 9.5" wheels 275-40/17 and they fit with no problems whatsoever.
Ken
Old Jun 10, 2003 | 11:50 PM
vosko's Avatar
the tire warranty is regardless of mileage
Old Jun 10, 2003 | 11:51 PM
vosko's Avatar
Ken
mine are on 9" rims! fits like a glove lol
