Oil changes with the KAAZ unit?
Old Jun 8, 2003 | 01:01 PM
racer rx's Avatar
How often should you change the Rear Diff. Oil with the KAAZ unit?
Old Jun 8, 2003 | 08:31 PM
apeiron
oil change
Old Jun 8, 2003 | 08:35 PM
apeiron
oil change
Hey,
Your supposed to change the oil every 1,500 miles... But meh.. I changed the oil on mine every 5. Depending onw here you live makes a little bit of a difference as well but nothing substantial.
The reason why I dont do mine so often is because I lack a full car lift so I gota do it gheto style, and before I had a pump I used to have to siphon the **** into the housing and it was shitty...
WHAT EVER YOU DO DO NOT GET THE GEAR OIL ON YORU CLOTHES. The smell is horrid and you will fear it the rest of your life.
but yea, hope that helps
you will be fine if you change it every 5,000 or less..
you can get the same weight gear oil at autozone or other various auto stores for a fraction of the price taht kaaz sells it for
