A few more questions about an 88 vert
Old Jun 8, 2003 | 11:55 AM
Question A few more questions about an 88 vert
I have a few questions about an 88 vert that I test drove. Here they are.
1. While shifting gears, it sticks as it shifts into thrid gear.
2. I noticed a lot of heat coming from under the shift boot as I was holding the shift ****. Is that normal?
3. I also noticed the slight smell of exaust when I was on the side of the car about mid way. Could that be a leak?
Thanks.
Old Jun 8, 2003 | 12:12 PM
downwinddave's Avatar
1. Sticks in second or will not go into 3rd?
2. Replace inner and outer rubber boot covers.
3. Leak, yes.
do a search:
https://www.rx7club.com/forum/search...der=descending
Old Jun 8, 2003 | 12:16 PM
It has no problem shifting into third, it just sticks a little when doing it.
Old Jun 8, 2003 | 01:16 PM
Icemark's Avatar
Yeah replace the tranny fluid with a good quality synthetic like Redline MT90 for the 3rd gear thing.
And it sounds like the shifter boots are torn and need replacing. Both the heat and exhaust smell can be from that.
Old Jun 8, 2003 | 02:53 PM
The change when I put in Redline MT 90 was very dramatic.
How is it when you down shift?
Old Jun 8, 2003 | 03:22 PM
The down shift is fine, very smooth for an original clutch on 120k. 3rd is the only gear that has a problem.
Old Jun 8, 2003 | 07:36 PM
Icemark's Avatar
Won't be the original clutch at 120K unless the previous owners only drove on highways/freeways
Old Jun 8, 2003 | 08:01 PM
1BADRX7's Avatar
The smell could be from the removal of the cats? Is the exhaust modified?
The heat like mentioned above is from the shifter boots needing replacement(cheap fix).
Change the fluid in the trans and see if that solves it.
How much are you getting the car for?
Old Jun 9, 2003 | 11:03 AM
The car was only driven on the freeway for commute, but the owner before him could have changed the clutch. He was the second owner.
The exaust has no modifications, it looks original, I'm getting the car for 3k.
Old Jun 9, 2003 | 11:08 AM
Icemark's Avatar
That is a little high (unless you are buying it from a dealer or the body and top are in great condition).
I bought my 88 'vert a year ago January for only $2500, but the paint was rather rough (I spent a couple of weekends buffing) and the interior had some water in it. But I did get a brand new top and the brakes/suspension were perfect.
If you are near the North Bay I would happy to check it out for you.
Old Jun 9, 2003 | 11:41 AM
Thanks for the offer Icemark, but I arranged for Mazda to have a compression test done on it and the guy called me this morning and sais someone payed cash on the spot for it last night. So I guess if he was asking too much, then I am mostly likely better off.
Donald Hampton
16
Nov 23, 2022 06:38 PM
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
